FS84
已解决
5,239 次查看
liubenjun
Hi NXP team,
    For FS84,Can I read Main OTP_REGISTERS data?If it can be read, please tell me how.Thanks!
标签 (1)
1 解答
5,152 次查看
guoweisun
这些regulators输出的值都是您选择的或者自己预定的,AMUX读出来的值您比较下就知道了,但是OTP寄存器里面的数值一般不再客户端支持读取。
在原帖中查看解决方案
8 回复数
5,153 次查看
guoweisun
5,139 次查看
liubenjun
谢谢!我知道预设的电压值了。
5,148 次查看
liubenjun
这些regulators输出的值是硬件还是软件设定的?
5,171 次查看
guoweisun
Do you know the value you set about these regulators?
5,156 次查看
liubenjun
Isn't the regulator configured by OTP?Are these voltages related to the Main OTP_REGISTERS configuration?
5,224 次查看
guoweisun
hi
Unfortunately I am afraid that you can't read it out!
5,182 次查看
liubenjun
Okay,Thank you for your reply,I have another question,I read some voltage values from the M_AMUX register as follows: VDDIO voltage = 3.23V, VBUCK1 voltage = 1.25V, VBUCK3 voltage = 2.32V, VPRE voltage = 3.29V, VBOOST voltage = 5.78V, etc. How do I know these voltage values are correct.
5,165 次查看
liubenjun
Thanks, and I read some voltage values ​​through M_AMUX register. For example: VDDIO voltage = 3.23V, VBUCK1 voltage = 1.25V, VBOOST voltage = 5.78V.So, how do I know that these voltage values ​​are correct.
