FS26 Replacement Part Number for MR-CANHUBK344
patricklanglois
We have the MR-CANHUBK344 evaluation board on which we want to base a new design. Looking at the schematics, I see a preliminary part number for the FS26 SBC. What would be the final part number these days to replace this one if I have to or if I want to use the same component.
patricklanglois
There is nothing in this thread that I could consider an acceptable solution. Based on my past experiences and reading other discussions, I think it's a matter of luck if we can get a proper answer from the NXP Tech Support. Feel free to close this thread if you can't be more explicit. BTW, I can consider as acceptable a simple answer like "we have no way to identify a single production part number to the preliminary one that is suitable to replace the FS26 chip on the MR-CANHUBK344 evaluation board." But, this might bring some questions about NXP's control over what they make.
patricklanglois
The kind of answer I'm looking for is similar to the one of the post "FS26 chip of S32K312EVB-Q172", but transposed to the eval board MR-CANHUBK344.
patricklanglois
My question is about the SBC not the mcu.
guoweisun
For the S32K344,you can select FS26 from below list:
patricklanglois
With no intent of disrespect, as you repeat your answer, I suppose that I must repeat my question following it...
I don't see the MR-CANHUBK344 evaluation board in your list. Is there a mistake here?
But at the end, what I want to know from my initial statement is simply:
What is the production part number for the FS26 SBC to specifically replace the one on the MR-CANHUBK344 evaluation board? Your list specifies other evaluation boards, not this one that we purchased. And, the schematics of this board are still pointing a preliminary part, while a production part probably exists now. Are all the components in your list a fit to replace the one on my evaluation board and to supply the S32K3? I want to identify the right variation of the FS26 SBC to properly analyze the evaluation board design.
P.S.: Initially, I was expecting an answer like @VanB was able to provide to the post "FS26 chip of S32K312EVB-Q172". Please let me know if I demand the impossible.
guoweisun
I compared your EVB FS26 regulator output sequence and Vout, there is no suitable FS26 OTP part for recommend, they are not match/different.
So you can try to buy A0 blank part and do OTP by yourself with the OTP socket board.
KITFS26SKTEVM FS26 Safety SBC Programming Socket Board | NXP Semiconductors
patricklanglois
I don't see the MR-CANHUBK344 evaluation board in this list. Is there a mistake? This list looks like an excerpt of a more complete document. Would you please provide the reference to the document where I can find the complete list if this one includes the evaluation board I mentioned here?
guoweisun
This EVB used this MCU:
guoweisun
Fort FS26 selection please refer to below:
