P2041 Serdes PLL could not work correct
14,511 次查看
zhaopingyang_sg
I use P2041 with LANE H as SGMII and Lane E/F as PCIE-2.
but when cpu bootup,I found SDRDS Register is as Follows:
|---B0RSTCTL = 0x26474507.
|---B1PLLCR0 = 0x0000000c.
|---B1PLLCR1 = 0x08000100.
it means that Serdes is reset failed.
follows is my RCW:
after this,i excute a reset sequence for SRDES,it out put as follows and reset failed at last:
-> serdes_reset
Set SD_RST
|---B0RSTCTL = 0x26474547.
SET SDPD and PLLRST
|---B0RSTCTL = 0x26474567.
SET RSTREQ
|---B0RSTCTL = 0x06474562.
Clear SD_RST SDPD and PLLRST
|---B0RSTCTL = 0x06474504.
value = 27 = 0x1b
-> serdes_dump
value = 27 = 0x1b
22 回复数
11,357 次查看
leowang1
会不会是焊接问题导致的?
13,601 次查看
ufedor
Please provide:
1) U-Boot log as text attachment
2) SerDes reference clocks frequencies
13,601 次查看
zhaopingyang_sg
hi,ufedor!
My operation system is vxWorks,no u-boot.
Serder reference clocks is 100M.
thanks...
13,601 次查看
ufedor
Both reference clocks or one?
If one - which exactly SD_REF_CLK1 or SD_REF_CLK2?
Please provide RCW in either form:
- text file of the RCW dump
- binary image
13,601 次查看
zhaopingyang_sg
Yes,both SD_REF_CLK is 100M。
RCW is as follows:
13,601 次查看
ufedor
Excuse me, by it was written "text file".
This means - not picture.
13,598 次查看
zhaopingyang_sg
sorry! by the way, system do not have sd_ref_clk_2.
0xf8000000: aa 55 aa 55 01 0e 01 00 4c 58 00 00 00 00 00 00
0xf8000010: 18 18 00 00 00 00 00 00 64 8e d0 c0 f7 c0 20 00
0xf8000020: de 80 00 00 40 00 00 00 00 00 00 00 00 00 00 00
0xf8000030: 00 00 00 00 f0 19 ce f3 00 00 00 00 00 00 00 00
0xf8000040: 00 00 00 00 00 00 00 00 09 13 80 c0 00 00 09 c4
0xf8000050: 09 00 00 10 00 00 00 00 09 13 80 c0 00 00 09 c4
0xf8000060: 09 00 00 14 00 00 00 00 09 13 80 c0 00 00 09 c4
0xf8000070: 09 00 00 18 81 d0 00 00 09 13 80 c0 00 00 09 c4
0xf8000080: 89 0b 00 50 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf8000090: 89 0b 00 54 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000a0: 89 0b 00 58 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000b0: 89 0b 00 5c 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000c0: 89 0b 00 90 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000d0: 89 0b 00 94 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000e0: 89 0b 00 98 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000f0: 89 0b 00 9c 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf8000100: 89 0b 01 08 00 00 00 12 09 13 80 c0 00 00 09 c4
0xf8000110: 89 02 10 08 00 00 f0 00 09 13 80 c0 00 00 09 c4
0xf8000120: 89 02 10 28 00 00 f0 00 09 13 80 c0 00 00 09 c4
0xf8000130: 89 02 10 48 00 00 f0 00 09 13 80 c0 00 00 09 c4
0xf8000140: 89 02 10 68 00 00 f0 00 09 13 80 c0 00 00 09 c4
0xf8000150: 09 13 80 00 00 00 00 00 08 13 80 40 8a da 60 88
13,598 次查看
ufedor
In this case SRDS_LPD_B2 - Lane C has to be powered down.
13,598 次查看
zhaopingyang_sg
thanks for your answer.
I set the lane C to power down.but it's still not work.new RCW is as follows:
0xf8000010: 18 18 00 00 00 00 00 00 64 8e d0 c0 ff c0 20 00
0xf8000150: 09 13 80 00 00 00 00 00 08 13 80 40 89 e0 dd 1f
the serder pll reset output message as follows:
-> serdes_reset
Set SD_RST
SET SDPD and PLLRST
|---B0RSTCTL = 0x264745e7.
SET RSTREQ
|---B0RSTCTL = 0x064745e1.
|---B0RSTCTL = 0x064745e4.
LAST Status.
13,600 次查看
ufedor
What are the following lines?
Have you programmed the RCW into a Flash?
13,600 次查看
zhaopingyang_sg
thanks for all your reply,do you have some document  to explain how configure SerDer and Debug it.
13,600 次查看
ufedor
SerDes parameters have to be configured in accordance with the QorIQ P2040 Reference Manual descriptions:
Table 3-13. SerDes Lane Multiplexing/Configuration
Table 4-14. Valid SerDes RCW Encodings and Reference Clocks
There are no additional documents concerning SerDes debugging.
Usually RCW is programmed into the boot Flash and tested by powering-on the board.
No additional debug or software control is needed because SerDes is configured by internal microcode using RCW data during POR sequence.
13,600 次查看
zhaopingyang_sg
Table 3-13. SerDes Lane Multiplexing/Configuration : I select 0x19 for use SGMII 4 for dtsec and PCIE2.
Table 4-14. Valid SerDes RCW Encodings and Reference Clocks: Ratio set 50:1 and set DIV to /2.
did some error in my RCW.
why SerDes PLL always could not lock?
thanks!
13,600 次查看
ufedor
Use a digital scope and provide traces of the SD_REF_CLK1 at the processor's pins.
13,600 次查看
zhaopingyang_sg
PIC1:REF_CLK_P and REF_CLK_N On each channel
PIC2: REF_CLK_P On oscilloprobe's GND and REF_CLK_N on oscilloprobe's signal pin
13,600 次查看
ufedor
Please provide complete processor connection schematics as PDF.
13,600 次查看
zhaopingyang_sg
Sorry I can not provide whole schematics as PDF,follwos is main schematics about  clock src and signals to CPU:
13,600 次查看
zhaopingyang_sg
ufedor‌ Could you give me some advise?thanks...
13,598 次查看
ufedor
I've already sent you response from the corresponding Technical Case.
I'm waiting for the complete processor connection schematics.
13,600 次查看
zhaopingyang_sg
  • How can I send you the schematics?
