I use P2041 with LANE H as SGMII and Lane E/F as PCIE-2.
but when cpu bootup,I found SDRDS Register is as Follows:
|---B0RSTCTL = 0x26474507.
|---B1PLLCR0 = 0x0000000c.
|---B1PLLCR1 = 0x08000100.
it means that Serdes is reset failed.
follows is my RCW:
after this,i excute a reset sequence for SRDES,it out put as follows and reset failed at last:
-> serdes_reset
Set SD_RST
|---B0RSTCTL = 0x26474547.
SET SDPD and PLLRST
|---B0RSTCTL = 0x26474567.
SET RSTREQ
|---B0RSTCTL = 0x06474562.
Clear SD_RST SDPD and PLLRST
|---B0RSTCTL = 0x06474504.
value = 27 = 0x1b
-> serdes_dump
value = 27 = 0x1b
hi,ufedor!
My operation system is vxWorks,no u-boot.
Serder reference clocks is 100M.
thanks...
Yes,both SD_REF_CLK is 100M。
RCW is as follows:
sorry! by the way, system do not have sd_ref_clk_2.
0xf8000000: aa 55 aa 55 01 0e 01 00 4c 58 00 00 00 00 00 00
0xf8000010: 18 18 00 00 00 00 00 00 64 8e d0 c0 f7 c0 20 00
0xf8000020: de 80 00 00 40 00 00 00 00 00 00 00 00 00 00 00
0xf8000030: 00 00 00 00 f0 19 ce f3 00 00 00 00 00 00 00 00
0xf8000040: 00 00 00 00 00 00 00 00 09 13 80 c0 00 00 09 c4
0xf8000050: 09 00 00 10 00 00 00 00 09 13 80 c0 00 00 09 c4
0xf8000060: 09 00 00 14 00 00 00 00 09 13 80 c0 00 00 09 c4
0xf8000070: 09 00 00 18 81 d0 00 00 09 13 80 c0 00 00 09 c4
0xf8000080: 89 0b 00 50 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf8000090: 89 0b 00 54 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000a0: 89 0b 00 58 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000b0: 89 0b 00 5c 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000c0: 89 0b 00 90 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000d0: 89 0b 00 94 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000e0: 89 0b 00 98 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf80000f0: 89 0b 00 9c 00 00 00 02 09 13 80 c0 00 00 09 c4
0xf8000100: 89 0b 01 08 00 00 00 12 09 13 80 c0 00 00 09 c4
0xf8000110: 89 02 10 08 00 00 f0 00 09 13 80 c0 00 00 09 c4
0xf8000120: 89 02 10 28 00 00 f0 00 09 13 80 c0 00 00 09 c4
0xf8000130: 89 02 10 48 00 00 f0 00 09 13 80 c0 00 00 09 c4
0xf8000140: 89 02 10 68 00 00 f0 00 09 13 80 c0 00 00 09 c4
0xf8000150: 09 13 80 00 00 00 00 00 08 13 80 40 8a da 60 88
thanks for your answer.
I set the lane C to power down.but it's still not work.new RCW is as follows:
0xf8000010: 18 18 00 00 00 00 00 00 64 8e d0 c0 ff c0 20 00
0xf8000150: 09 13 80 00 00 00 00 00 08 13 80 40 89 e0 dd 1f
the serder pll reset output message as follows:
-> serdes_reset
Set SD_RST
SET SDPD and PLLRST
|---B0RSTCTL = 0x264745e7.
SET RSTREQ
|---B0RSTCTL = 0x064745e1.
|---B0RSTCTL = 0x064745e4.
LAST Status.
thanks for all your reply,do you have some document to explain how configure SerDer and Debug it.
SerDes parameters have to be configured in accordance with the QorIQ P2040 Reference Manual descriptions:
Table 3-13. SerDes Lane Multiplexing/Configuration
Table 4-14. Valid SerDes RCW Encodings and Reference Clocks
There are no additional documents concerning SerDes debugging.
Usually RCW is programmed into the boot Flash and tested by powering-on the board.
No additional debug or software control is needed because SerDes is configured by internal microcode using RCW data during POR sequence.
Table 3-13. SerDes Lane Multiplexing/Configuration : I select 0x19 for use SGMII 4 for dtsec and PCIE2.
Table 4-14. Valid SerDes RCW Encodings and Reference Clocks: Ratio set 50:1 and set DIV to /2.
did some error in my RCW.
why SerDes PLL always could not lock?
thanks!
PIC1:REF_CLK_P and REF_CLK_N On each channel
PIC2: REF_CLK_P On oscilloprobe's GND and REF_CLK_N on oscilloprobe's signal pin
Sorry I can not provide whole schematics as PDF,follwos is main schematics about clock src and signals to CPU:
