TDA8034 deactivate sequence
8,447 次查看
Slience5
There is a question about TDA8034 deactivate sequence. The spec defines the CMDVCC goes high firstly then the reset signal goes low and then the clock stops. However, the measured waveform on a Dell laptop indicates the sequence is reversed. Is that a problem?
Josh
4 回复数
8,417 次查看
Slience5
Hi Tony,
Thanks for the quick response. I should have attach the activate and deactivate sequence waveform in the spreadsheet to the ticket. I could upload the file again. It contains the okay and ng part waveform, though, I can't tell the differences. The TDA8034 schematics is in the tab of the spreadsheet as well. Please let me know if you still don't see the spreadsheet.
Josh
8,398 次查看
danielchen
Hi @Slience5
From the waveform,  I can see the OK part and NG part,   mean some devices are okay and some are NG in your side?   does the NG part not work correctly?
I don't see any difference that can impact the functionality.
8,394 次查看
Slience5
Hi Daniel,
My apologies for calling you Tony. Working on many things at the same time.
I can't tell the difference between Ok and NG part, too. However, we hope to consult with you if you have any concern over the deactivate sequence which doesn't match the spec. The NG parts sometimes not work properly, not all the time. We can rule out the timing violation from causing the issue if you don't have concerns.
Josh
8,420 次查看
danielchen
Hi @Slience5
Could you please attach the activation sequence and deactivation sequence in your side , and schematics here for further analyzing?  or through a ticket is also OK.
标记 (1)
