PNEV7462 example uploading
2,929 次查看
xlivnenko_michael
Hi, I'm new in NXP and I have a problem with uploading the example to the board.
I have a PNEV7462C dev board and want to upload phExCcid example using a J-Link or a divece as a mass storage. I've upload support packege and open the example with MCUXpress IDE, if I run the debug - the device works fine, but if I want to upload with RUN after uploading nothing works. Also I've tried with mass storage, upload EEPROM file separetly and bin file that was creating while building and nothing works.
8 回复数
2,890 次查看
xlivnenko_michael
I succesfuly open the needed project, but the problem is that the example works only in debug mode. When I use program flash or uploading using mass storage nothing works
2,841 次查看
danielchen
Hi @xlivnenko_michael
Just checked the properties of this project, it programmed into flash.  it should work without debug.  But no print on debug console.
2,906 次查看
danielchen
Sorry I am not sure I catch your question,  I would suggest you take a look at the um10883: PN7462 Quick Start Guider,  it describes how to start and develop software and hardware with PN7462 family
https://www.nxp.com/docs/en/user-guide/UM10883.pdf
2,889 次查看
xlivnenko_michael
I uploaded the code from this manual and succesfully run the needed example, but it works only in debug mode, if I program flash using JLink and MCUXpresso or using masstorage for uploading - nothing works
2,868 次查看
danielchen
which demo you are using, let me try to reproduce this issue on my side
2,802 次查看
xlivnenko_michael
Any news?
2,798 次查看
danielchen
This demo works without debugger,  but you can not see the debug output in MCUXpresso console, since you stopped debugging.   actually it works
2,863 次查看
xlivnenko_michael
Ccid example, for flashing JLink
