Hi out there,
currently im working on the LS10121ATSN-PA platform - installed with OpenIL. But after first steps with SJA1105 Tool to change switch configuration i get the error "could not open /lib/firmware/sja1105.bin for write". Where can i get the firmware?
Greetings Frank
Solved! Go to Solution.
I found a solution by myself. I used the offical Image OpenIL which contains the firmware for the SJA1105.
