CW_TAP Software tool
1,274 次查看
shinbo
Attempt to compile RCW using the codeword TAP.
What software tool do you use and what is the debug file?
1,221 次查看
Hector_Villarruel
Code Warrior is the the Software tool of the CodeWarrior TAP,
In the following link you can find the "CodeWarrior TAP Probe User Guide"
This document Guides you in the process to use correctly the CodeWarrior TAP, how to connect it, use it, and more.
https://www.nxp.com/docs/en/user-guide/CWTAPUG.pdf
Hector Villarruel
