CDMA decode
CDMA decode
2,601 次查看
jessesun
I using TEF82XX enables CDMA(MIMO) signal. If the s32r45 can be using to decode the MIMO signal? Is there any sample I can reference?
#TEF82XX
#S32R45
标记 (2)
2,539 次查看
petervlna
2,576 次查看
petervlna
Yes it can be used for such purpose. However all available example codes are in RTD package
But I am not sure whether there is processing of TEF82xx signals implemented in some libraries or so as we do not have demo board for TEF82xx and S32R45. Most probably there is no such solution available.
Peter
2,570 次查看
jessesun
Hi Peter,
Thank you for your reply. Another question is that where I can get example codes are in RTD package of s32r45 as I check that I have no these codes.
Best Regrads,
Jesse
2,540 次查看
petervlna
You can get it from our web page of S32R45:
https://www.nxp.com/products/processors-and-microcontrollers/s32-automotive-platform/s32r-radar-proc...
Peter
