BDM doubt
已解决
BDM doubt
跳至解决方案
2,613 次查看
isaacmartinezsa
if a program BDM HCS08 series.
can program the "MC9S08SE8CRL"?,
or is there except for a microcontroller?,
I'm new to microcontrollers
标签 (1)
1 解答
2,397 次查看
carloscuev
Contributor V
If I undestand your question correctly, you want to know if a HCS08 programmer will program a MC9S08SE8CRL. The answer is yes, there's nothing apecial about SE8, has S08 core.
在原帖中查看解决方案
3 回复数
2,398 次查看
carloscuev
Contributor V
2,397 次查看
isaacmartinezsa
Same thing that S08 HCS08,
if yes why they put HC?
2,397 次查看
carloscuev
Contributor V
Yes HCS08 and S08 is the same, what's not the same is HC08 and HCS08. HC08 is the old motorola core, which was updated and now it's called HCS08, or S08 for short.
