Is NTM88's pressure inlet waterproof?
ankit2631
I wanted to know if NTM88 can work if water goes inside its pressure hole. because i am using it for Tire pressure monitoring of tractor tires and tractor tires have some amount of water filled into them, which will lead to water entering inside the IC. So will this damage the IC?
guoweisun
If only the water goes inside its pressure hole,there is no problem.
guoweisun
