RDDSCSENSORLESSBLDC: 3-Phase Brushless DC Motor Sensorless Control Reference Design using 56F801X
Overview
This reference design is a 3-phase brushless DC (BLDC) motor sensorless drive for fans, pumps and compressors based on the low-cost NXP® 56F801x digital signal controllers (DSCs).
  • The concept is a closed-loop speed-controlled BLDC drive with no need for position or speed sensors
  • AIt serves as a reference design for a BLDC motor sensorless control system, ideal for fan, pump and compressor applications
  • Power stages used by the application are designed for 12V DC line voltage and 3Aor 8A output current
  • The reference manual provides a detailed description of the application, including design of the hardware and the software
Features
  • 3-phase brushless DC motor sensorless drive
  • Designed to fit into fan, pump and compressor applications
  • Uses 56F8013 32 MIPS Digital Signal Controller
  • Available for two power stages and two motors
  • Input power supply voltage +12 VDC for power stages
  • Control techniques incorporate:
    • Sensorless, trapezoidal control of 3-phase BLDC motor with back-EMF sensing
    • ADC zero crossing sensing for sensorless control
    • Closed-loop speed control using PI controller
    • Adjustable DC-bus current limitation PI controller
    • Motoring mode
    • Both directions of rotation
  • Speed range: 200-2000 and 800-8000 RPM (depending on the motor used)
  • Manual interface (RUN/STOP switch, UP/DOWN pushbuttons)
  • FreeMaster interface for monitoring, controlling and tuning
  • Fault protection (DC-bus over-current, DC-bus under-voltage, DC-bus over-voltage)
  • Automatic calibration of phase back-EMF measurements
  • 20 kHz PWM switching frequency
  • Easy to tune for different power stages and motors.
Block Diagram
Board
Design Resources
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1114477%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDDSCSENSORLESSBLDC%3A%2056F801X%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%203%20%E7%9B%B8%E3%83%96%E3%83%A9%E3%82%B7%E3%83%AC%E3%82%B9%20DC%20%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%E5%88%B6%E5%BE%A1%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114477%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCSENSORLESSBLDC-3-Phase-Brushless-DC-Motor-Sensorless%2Fta-p%2F1114477%23toc-hId-381531728%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCSENSORLESSBLDC-3-Phase-Brushless-DC-Motor-Sensorless%2Fta-p%2F1114477%23toc-hId--1425922735%22%20target%3D%22_blank%22%3E%E7%89%B9%E9%95%B7%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCSENSORLESSBLDC-3-Phase-Brushless-DC-Motor-Sensorless%2Fta-p%2F1114477%23toc-hId-1061590098%22%20target%3D%22_blank%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCSENSORLESSBLDC-3-Phase-Brushless-DC-Motor-Sensorless%2Fta-p%2F1114477%23toc-hId--745864365%22%20target%3D%22_blank%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCSENSORLESSBLDC-3-Phase-Brushless-DC-Motor-Sensorless%2Fta-p%2F1114477%23toc-hId-1741648468%22%20target%3D%22_blank%22%3E%E8%A8%AD%E8%A8%88%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-381531728%22%20id%3D%22toc-hId-1304221432%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AF%E3%80%81%E4%BD%8E%E3%82%B3%E3%82%B9%E3%83%88%E3%81%AE%20NXP%C2%AE%2056F801x%20%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20(DSC)%20%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%99%E3%82%8B%E3%80%81%E3%83%95%E3%82%A1%E3%83%B3%E3%80%81%E3%83%9D%E3%83%B3%E3%83%97%E3%80%81%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%B5%E5%90%91%E3%81%91%E3%81%AE%203%20%E7%9B%B8%E3%83%96%E3%83%A9%E3%82%B7%E3%83%AC%E3%82%B9%20DC%20(BLDC)%20%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BB%E3%83%97%E3%83%88%E3%81%AF%E3%80%81%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%84%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%AA%E3%81%84%E9%96%89%E3%83%AB%E3%83%BC%E3%83%97%E9%80%9F%E5%BA%A6%E5%88%B6%E5%BE%A1BLDC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%3EA%E3%81%93%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AF%E3%80%81BLDC%20%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%E5%88%B6%E5%BE%A1%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%83%B3%E3%80%81%E3%83%9D%E3%83%B3%E3%83%97%E3%80%81%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%B5%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E9%9B%BB%E5%8A%9B%E6%AE%B5%E3%81%AF%E3%80%8112V%20DC%E3%83%A9%E3%82%A4%E3%83%B3%E9%9B%BB%E5%9C%A7%E3%81%A83A%E3%81%BE%E3%81%9F%E3%81%AF8A%E3%81%AE%E5%87%BA%E5%8A%9B%E9%9B%BB%E6%B5%81%E7%94%A8%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A8%AD%E8%A8%88%E3%81%AA%E3%81%A9%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1425922735%22%20id%3D%22toc-hId--503233031%22%3E%E7%89%B9%E9%95%B7%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E3%E7%9B%B8%E3%83%96%E3%83%A9%E3%82%B7%E3%83%AC%E3%82%B9DC%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%AC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%83%95%E3%82%A1%E3%83%B3%E3%80%81%E3%83%9D%E3%83%B3%E3%83%97%E3%80%81%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%B5%E3%83%BC%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%81%A9%E5%90%88%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E56F8013%2032%20MIPS%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E2%E3%81%A4%E3%81%AE%E3%83%91%E3%83%AF%E3%83%BC%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%A82%E3%81%A4%E3%81%AE%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E5%85%A5%E5%8A%9B%E9%9B%BB%E6%BA%90%E9%9B%BB%E5%9C%A7%20%2B12%20VDC%20(%E3%83%91%E3%83%AF%E3%83%BC%E6%AE%B5%E7%94%A8)%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E5%88%B6%E5%BE%A1%E6%8A%80%E8%A1%93%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%8C%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E9%80%86%E8%B5%B7%E9%9B%BB%E5%8A%9B%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%82%92%E7%94%A8%E3%81%84%E3%81%9F3%E7%9B%B8BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%E5%8F%B0%E5%BD%A2%E5%88%B6%E5%BE%A1%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%AC%E3%82%B9%E5%88%B6%E5%BE%A1%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AEADC%E3%82%BC%E3%83%AD%E3%82%AF%E3%83%AD%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EPI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AB%E3%82%88%E3%82%8B%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%83%89%E3%83%AB%E3%83%BC%E3%83%97%E9%80%9F%E5%BA%A6%E5%88%B6%E5%BE%A1%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E8%AA%BF%E6%95%B4%E5%8F%AF%E8%83%BD%E3%81%AADC%E3%83%90%E3%82%B9%E9%9B%BB%E6%B5%81%E5%88%B6%E9%99%90PI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E4%B8%A1%E5%9B%9E%E8%BB%A2%E6%96%B9%E5%90%91%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E9%80%9F%E5%BA%A6%E7%AF%84%E5%9B%B2%3A200-2000%E3%81%8A%E3%82%88%E3%81%B3800-8000%20RPM(%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E6%89%8B%E5%8B%95%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9(RUN%20%2F%20STOP%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%81UP%2FDOWN%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%83%9C%E3%82%BF%E3%83%B3)%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E7%9B%A3%E8%A6%96%E3%80%81%E5%88%B6%E5%BE%A1%E3%80%81%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AEFreeMaster%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E9%9A%9C%E5%AE%B3%E4%BF%9D%E8%AD%B7(DC%E3%83%90%E3%82%B9%E9%81%8E%E9%9B%BB%E6%B5%81%E3%80%81DC%E3%83%90%E3%82%B9%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%80%81DC%E3%83%90%E3%82%B9%E9%81%8E%E9%9B%BB%E5%9C%A7)%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E4%BD%8D%E7%9B%B8%E9%80%86%E8%B5%B7%E9%9B%BB%E5%8A%9B%E6%B8%AC%E5%AE%9A%E3%81%AE%E8%87%AA%E5%8B%95%E6%A0%A1%E6%AD%A3%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E20kHz%E3%81%AEPWM%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%91%E3%83%AF%E3%83%BC%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%82%84%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E7%B0%A1%E5%8D%98%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1061590098%22%20id%3D%22toc-hId-1984279802%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RDDSCSENSORLESSBLDCBLK.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RDDSCSENSORLESSBLDCBLK.gif%22%20style%3D%22width%3A%20720px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111768i4FF0DD76F0A8542B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RDDSCSENSORLESSBLDCBLK.gif%22%20alt%3D%22RDDSCSENSORLESSBLDCBLK.gif%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERDDSCSENSORLESSBLDCBLK.gif%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--745864365%22%20id%3D%22toc-hId-176825339%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RDDSCSENSORLESSBLDCIMG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RDDSCSENSORLESSBLDCIMG.jpg%22%20style%3D%22width%3A%20862px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111769iE8156F159809AFFA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RDDSCSENSORLESSBLDCIMG.jpg%22%20alt%3D%22RDDSCSENSORLESSBLDCIMG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERDDSCSENSORLESSBLDCIMG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1741648468%22%20id%3D%22toc-hId--1630629124%22%3E%E8%A8%AD%E8%A8%88%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114477%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎08-11-2020 02:09 PM
更新者:
