NTAG213 Counter
NTAG213 Counter
AW1511
Is there any way to increment the NFC counter on power up?
The data sheet shows that the counter will not be incremented until a read or fast read command. Is that correct?
I can think of a number of relevant use cases where counter increment on power up without the need for an external read command would be useful.
Andrew
Ricardo_Zamora
Hope you are doing well.
The NFC counter will be automatically increased at the first READ or FAST_READ command after a power on reset.
So, the command is necessary to increase the counter value.
Ricardo
AW1511
Is there any update on this counter functionality?
