NTAG213 Counter
NTAG213 Counter
2,020 次查看
AW1511
Is there any way to increment the NFC counter on power up?
The data sheet shows that the counter will not be incremented until a read or fast read command. Is that correct?
I can think of a number of relevant use cases where counter increment on power up without the need for an external read command would be useful.
Andrew
1,977 次查看
Ricardo_Zamora
Hope you are doing well.
The NFC counter will be automatically increased at the first READ or FAST_READ command after a power on reset.
So, the command is necessary to increase the counter value.
Ricardo
1,988 次查看
AW1511
Is there any update on this counter functionality?
