How to remove the Password Protection NTAG213?
6,313 次查看
stevekuh
Writing Java for Android app, I am able to set the password protection for the NTAG213 tag. However, upon trying to remove the password, it does not work. Could someone help with a document or the correct procedure to follow? The data sheet does not include any examples or explain clearly. -Steve
标签 (1)
5 回复数
4,537 次查看
Alaa_shahin
Please can you share how to set password protection NTAG213 for Android project?
Please can you send demo code/project to following link?
Thanks a lot.
[email protected]
标记 (2)
4,817 次查看
naingmyothaw
Thanks a lot.
[email protected]
5,842 次查看
stevekuh
Upon setting the Password Protection, is it possible for an attacker to reverse the protection by writing FFh to Auth0?
5,842 次查看
IvanRuiz
Changing this field is possible only in the Authenticated state, after a successful password authentication.
BR,
Ivan.
5,842 次查看
IvanRuiz
If password protection is no longer required, please set AUTH0 to FFh, this is the initial state of NTAG21x where the password protection is disabled.
Hope this helps.
BR,
Ivan.
