How to remove the Password Protection NTAG213?
6,322件の閲覧回数
stevekuh
Writing Java for Android app, I am able to set the password protection for the NTAG213 tag. However, upon trying to remove the password, it does not work. Could someone help with a document or the correct procedure to follow? The data sheet does not include any examples or explain clearly. -Steve
5 返答(返信)
4,546件の閲覧回数
Alaa_shahin
Please can you share how to set password protection NTAG213 for Android project?
Please can you send demo code/project to following link?
Thanks a lot.
[email protected]
タグ(2)
4,826件の閲覧回数
naingmyothaw
Thanks a lot.
[email protected]
5,851件の閲覧回数
stevekuh
Upon setting the Password Protection, is it possible for an attacker to reverse the protection by writing FFh to Auth0?
5,851件の閲覧回数
IvanRuiz
Changing this field is possible only in the Authenticated state, after a successful password authentication.
BR,
Ivan.
5,851件の閲覧回数
IvanRuiz
If password protection is no longer required, please set AUTH0 to FFh, this is the initial state of NTAG21x where the password protection is disabled.
Hope this helps.
BR,
Ivan.
