How to Use Linux CCID driver for PN7462 DEMO Board
Environments & Devices
--Hardware
1、PN7462 DEMO Board(PNEV7642B)
--Software
1、Ubuntu 16.04 desktop
2、Test tools
---libusb
---pcsc-lite
---ccid driver
---opensc
         Before testing, please install above test tools to Ubuntu 16.04 according to document on the link https://community.nxp.com/docs/DOC-334952 !
         Then follow steps below to begin testing PN7462 DEMO board by above test tools.
1、Update firmware of PN7462 DEMO board
         Please update firmware of PN7462 DEMO board according to UM10915.pdf, then test it on windows, ensuring PN7462 DEMO board can normally work at CCID protocol on window platform.
2、Connecting PN7462 DEMO Board to PC USB via USB OTG Cable.
         On PENV7462B side, X3 connector should be used for USB OTG cable.
3、Using lsusb to list USB devices
weidong@ubuntu:~$ lsusb
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 004: ID 0e0f:0008 VMware, Inc.
Bus 002 Device 005: ID 1fc9:0117 NXP Semiconductors
         Last line is PN7472 DEMO board.
4、Open 2 terminals at the same time on Ubuntu desktop
(1) One terminal is used to run “pcsc” command
weidong@ubuntu:~$ sudo /usr/local/sbin/pcscd -adf
[sudo] password for weidong:
00000000 pcscdaemon.c:345:main() pcscd set to foreground with debug send to stdout
00012288 configfile.l:361:DBGetReaderList() Parsing conf file: /usr/local/etc/reader.conf.d
00000037 pcscdaemon.c:658:main() pcsc-lite 1.8.22 daemon ready.
00023126 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1D6B, PID: 0x0001, path: /dev/bus/usb/002/001
00000101 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1D6B, PID: 0x0001, path: /dev/bus/usb/002/001
00000113 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0003, path: /dev/bus/usb/002/002
00000112 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1D6B, PID: 0x0001, path: /dev/bus/usb/002/001
00000160 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0002, path: /dev/bus/usb/002/003
00000152 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0008, path: /dev/bus/usb/002/004
00000115 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0008, path: /dev/bus/usb/002/004
00000165 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0002, path: /dev/bus/usb/002/003
00000263 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1D6B, PID: 0x0002, path: /dev/bus/usb/001/001
^V56546837 hotplug_libudev.c:651:HPEstablishUSBNotifications() USB Device add
00000101 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1FC9, PID: 0x0117, path: /dev/bus/usb/002/006
00000007 hotplug_libudev.c:436:HPAddDevice() Adding USB device: PN7462 USB Reader
00000045 readerfactory.c:1074:RFInitializeReader() Attempting startup of PN7462 USB Reader (1.00) 00 00 using /usr/local/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Linux/libccid.so
00127887 readerfactory.c:949:RFBindFunctions() Loading IFD Handler 3.0
00000236 ifdhandler.c:1965:init_driver() Driver version: 1.4.27
00000477 ifdhandler.c:1982:init_driver() LogLevel: 0x0003
00000004 ifdhandler.c:1993:init_driver() DriverOptions: 0x0000
00000165 ifdhandler.c:111:CreateChannelByNameOrChannel() Lun: 0, device: usb:1fc9/0117:libudev:0:/dev/bus/usb/002/006
00000021 ccid_usb.c:302:OpenUSBByName() Using: /usr/local/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Info.plist
00000727 ccid_usb.c:320:OpenUSBByName() ifdManufacturerString: Ludovic Rousseau ([email protected])
00000016 ccid_usb.c:321:OpenUSBByName() ifdProductString: Generic CCID driver
00000004 ccid_usb.c:322:OpenUSBByName() Copyright: This driver is protected by terms of the GNU Lesser General Public License version 2.1, or (at your option) any later version.
00000433 ccid_usb.c:656:OpenUSBByName() Found Vendor/Product: 1FC9/0117 (PN7462 USB Reader)
00000005 ccid_usb.c:658:OpenUSBByName() Using USB bus/device: 2/6
00000021 ccid_usb.c:717:OpenUSBByName() bNumDataRatesSupported is 0
00128471 ifdhandler.c:382:IFDHGetCapabilities() tag: 0xFB3, usb:1fc9/0117:libudev:0:/dev/bus/usb/002/006 (lun: 0)
00000027 readerfactory.c:396:RFAddReader() Using the reader polling thread
00004709 ifdhandler.c:382:IFDHGetCapabilities() tag: 0xFAE, usb:1fc9/0117:libudev:0:/dev/bus/usb/002/006 (lun: 0)
00000023 ifdhandler.c:477:IFDHGetCapabilities() Reader supports 1 slot(s)
(2)The other terminal is used to run “"testpcsc " in pcsc-lite/src source code
weidong@ubuntu:~/ccid/pcsc-lite-1.8.22/src$ ./testpcsc
MUSCLE PC/SC Lite unitary test Program
THIS PROGRAM IS NOT DESIGNED AS A TESTING TOOL FOR END USERS!
Do NOT use it unless you really know what you do.
Testing SCardEstablishContext        : Command successful.
Testing SCardIsValidContext   : Command successful.
Testing SCardIsValidContext   : Invalid handle. (don't panic)
Testing SCardListReaderGroups      : Command successful.
Group 01: SCard$DefaultReaders
Testing SCardFreeMemory               : Command successful.
Testing SCardListReaders        : Command successful.
Reader 01: PN7462 USB Reader (1.00) 00 00
Waiting for card insertion        :
         2 screenshots for above 2 terminals:
5、Test cards (All cards are contactless)
(1) MIFARE Plus x 4K card
Re move it:
(2) MIFARE Nano card
         Note: testpcsc should be run again.
Remove it:
(3) MIFARE EV1 card
Remove it:
6、Using Opensc-tool to Test cards
         Open a new terminal for running the command, please!
(1)No cards
(2) MIFARE Plus x 4K card (close to antenna , then run opensc-tool)
(3) MIFARE Nano card
(4) MIFARE EV1 card
   TIC Weidong Sun
2018-07-09
添付
コメント
Hi Wigros Sun,
        How to Get Windows CE CCID driver for PN7462 DEMO Board?
Here is related to reference about ccid driver.
1. How to install related tools
https://community.nxp.com/t5/NFC-Knowledge-Base/Installation-of-Linux-CCID-driver-For-NFC-Reader/ta-...
2. ccid website
https://ccid.apdu.fr/
%3CLINGO-SUB%20id%3D%22lingo-sub-1125050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7462%20DEMO%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%3E%E7%92%B0%E5%A2%83%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E--%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1%3C%2FSPAN%3E%E3%80%81%3CSPAN%3EPN7462%20DEMO%20Board(PNEV7642B)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E--%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1%3C%2FSPAN%3E%E3%80%81%3CSPAN%3EUbuntu%2016.04%20desktop%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2%3C%2FSPAN%3E%E3%80%81%3CSPAN%3E%E3%83%86%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E---libusb%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E---pcsc-lite%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E---ccid%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E---opensc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-334952%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-334952%3C%2FA%3E%20%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92Ubuntu%2016.04%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6PN7462%20DEMO%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%E3%80%81%3CSPAN%3EPN7462%20DEMO%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EUM10915.pdf%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6PN7462%20DEMO%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81Windows%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%80%81PN7462%20DEMO%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E4%B8%8A%E3%81%AECCID%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E2%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%E3%80%81%3CSPAN%3EPN7462%20DEMO%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92USB%20OTG%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7PC%20USB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPENV7462B%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81USB%20OTG%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%81%AFX3%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65098iE2CB8F1BFF937FE1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E3%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%E3%80%81%3CSPAN%3Elsusb%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eweidong%40ubuntu%3A~%24%20lsusb%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9002%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9002%3AID%200e0f%3A0003%20VMware%E3%80%81Inc.%E4%BB%AE%E6%83%B3%E3%83%9E%E3%82%A6%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9002%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9003%3AID%200e0f%3A0002%20VMware%2C%20Inc.%20%E4%BB%AE%E6%83%B3USB%E3%83%8F%E3%83%96%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9001%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9001%3AID%201d6b%3A0002%20Linux%20Foundation2.0%E3%83%AB%E3%83%BC%E3%83%88%E3%83%8F%E3%83%96%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9002%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9001%3AID%201d6b%3A0001%20Linux%20Foundation1.1%E3%83%AB%E3%83%BC%E3%83%88%E3%83%8F%E3%83%96%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9%20002%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20004%3A%20ID%200e0f%3A0008%20VMware%2C%20Inc.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9002%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9005%3AID%20%3CSTRONG%3E1fc9%3C%2FSTRONG%3E%3A%3CSTRONG%3E0117%3C%2FSTRONG%3E%20NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E8%A1%8C%E3%81%AFPN7472%20DEMO%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%E3%80%81%3CSPAN%3EUbuntu%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%A72%E3%81%A4%E3%81%AE%E7%AB%AF%E6%9C%AB%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20553px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65120iDB3861137F811A26%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E(1)%201%E3%81%A4%E3%81%AE%E7%AB%AF%E6%9C%AB%E3%81%A7%E3%80%8Cpcsc%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eweidong%40ubuntu%3A~%24%20sudo%20%2Fusr%2Flocal%2Fsbin%2Fpcscd%20-adf%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5Bsudo%5DWeidong%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000000%20pcscdaemon.c%3A345%3Amain()pcscd%20%E3%82%92%E3%83%95%E3%82%A9%E3%82%A2%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81debug%20send%20to%20stdout%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00012288%20configfile.l%3A361%3ADBGetReaderList()%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%A7%A3%E6%9E%90%3A%20%2Fusr%2Flocal%2Fetc%2Freader.conf.d%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000037%20pcscdaemon.c%3A658%3Amain()pcsc-lite%201.8.22%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E5%AF%BE%E5%BF%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00023126%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1D6B%E3%80%81PID%3A0x0001%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F001%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000101%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1D6B%E3%80%81PID%3A0x0001%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F001%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000113%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0003%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F002%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000112%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1D6B%E3%80%81PID%3A0x0001%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F001%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000160%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0002%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F003%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000152%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0008%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F004%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000115%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0008%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F004%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000165%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0002%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F003%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000263%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1D6B%E3%80%81PID%3A0x0002%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20001%2F001%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5EV56546837%20hotplug_libudev.c%3A651%3AHPEstablishUSBNotifications()USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000101%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1FC9%E3%80%81PID%3A0x0117%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F006%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000007%20hotplug_libudev.c%3A436%3AHPAddDevice()USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%BF%BD%E5%8A%A0%3APN7462USB%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000045%20readerfactory.c%3A1074%3ARFInitializeReader()%2Fusr%2Flocal%2Flib%2Fpcsc%2Fdrivers%2Fifd-ccid.bundle%2FContents%2FLinux%2Flibccid.so%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20PN7462%20USB%20Reader%20(1.00)%2000%2000%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ereaderfactory.c%3A949%3ARFBindFunctions()00127887IFD%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%203.0%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000236%20ifdhandler.c%3A1965%3Ainit_driver()%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A1.4.27%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000477%20ifdhandler.c%3A1982%3Ainit_driver()%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%99%E3%83%AB%3A0x0003%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000004%20ifdhandler.c%3A1993%3Ainit_driver()%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3A0x0000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000165%20ifdhandler.c%3A111%3ACreateChannelByNameOrChannel()Lun%3A0%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3Ausb%3A1fc9%2F0117%3Alibudev%3A0%3A%2Fdev%2Fbus%2Fusb%2F002%2F006%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000021%20ccid_usb.c%3A302%3AOpenUSBByName()%E4%BD%BF%E7%94%A8%3A%20%2Fusr%2Flocal%2Flib%2Fpcsc%2Fdrivers%2Fifd-ccid.bundle%2FContents%2FInfo.plist%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E00000727%20ccid_usb.c%3A320%3AOpenUSBByName()%20ifdManufacturerString%3A%20Ludovic%20Rousseau%20(%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aludovic.rousseau%40free.fr%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eludovic.rousseau%40free.fr%3C%2FA%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000016%20ccid_usb.c%3A321%3AOpenUSBByName()ifdProductString%3A%20%E6%B1%8E%E7%94%A8%20CCID%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000004%20ccid_usb.c%3A322%3AOpenUSBByName()%E8%91%97%E4%BD%9C%E6%A8%A9%3A%20%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GNU%20Lesser%20General%20Public%20License%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.1%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(%E4%BB%BB%E6%84%8F)%20%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000433%20ccid_usb.c%3A656%3AOpenUSBByName()%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%2F%E8%A3%BD%E5%93%81%3A%201FC9%2F0117%20(PN7462%20USB%20%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000005%20ccid_usb.c%3A658%3AOpenUSBByName()USB%E3%83%90%E3%82%B9%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E4%BD%BF%E7%94%A8%3A2%2F6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000021%20ccid_usb.c%3A717%3AOpenUSBByName()bNumDataRatesSupported%20%E3%81%AF%200%20%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00128471%20ifdhandler.c%3A382%3AIFDHGetCapabilities()%E3%82%BF%E3%82%B0%3A%200xFB3%2C%20usb%3A1fc9%2F0117%3Alibudev%3A0%3A%2Fdev%2Fbus%2Fusb%2F002%2F006%20(LUN%3A%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000027%20readerfactory.c%3A396%3ARFAddReader()%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00004709%20ifdhandler.c%3A382%3AIFDHGetCapabilities()%E3%82%BF%E3%82%B0%3A%200xFAE%2C%20usb%3A1fc9%2F0117%3Alibudev%3A0%3A%2Fdev%2Fbus%2Fusb%2F002%2F006%20(LUN%3A%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E00000023%20ifdhandler.c%3A477%3AIFDHGetCapabilities()%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF1%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E(2)%E3%82%82%E3%81%861%E3%81%A4%E3%81%AE%E7%AB%AF%E6%9C%AB%E3%81%AF%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%E3%80%81pcsc-lite%2Fsrc%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%80%8Ctestpcsc%E3%80%8D%3C%2FSTRONG%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%3Eweidong%40ubuntu%3A~%2Fccid%2Fpcsc-lite-1.8.22%2Fsrc%24%20.%2Ftestpcsc%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMUSCLE%20PC%2FSC%20Lite%20%E3%83%A6%E3%83%8B%E3%82%BF%E3%83%AA%E3%83%BC%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E3%80%81%E3%82%A8%E3%83%B3%E3%83%89%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%91%E3%81%91%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%9C%AC%E5%BD%93%E3%81%AB%E4%BD%95%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%89%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCardEstablishContext%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCardIsValidContext%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCardIsValidContext%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82(%E6%85%8C%E3%81%A6%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ETesting%20SCardListReaderGroups%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%9701%3ASCard%24DefaultReaders%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCardFreeMemory%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCardListReaders%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCardListReaders%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC01%3APN7462%20USB%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC(1.00)00%2000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%AB%E3%83%BC%E3%83%89%E6%8C%BF%E5%85%A5%E5%BE%85%E3%81%A1%20%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B8%8A%E8%A8%98%E3%81%AE2%E3%81%A4%E3%81%AE%E7%AB%AF%E6%9C%AB%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%882%E6%9E%9A%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65121i082A6538323A90D7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%E3%80%81%3CSPAN%3E%E3%83%86%E3%82%B9%E3%83%88%E3%82%AB%E3%83%BC%E3%83%89(%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E9%9D%9E%E6%8E%A5%E8%A7%A6%E5%9E%8B)%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20178px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65122iB5A908F1A571EA78%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20179px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65123iA612A96DDC2353C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20187px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65221i4F6E2AE25D4231A2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(1)MIFARE%E3%83%97%E3%83%A9%E3%82%B9%C3%974K%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20553px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65222iFDC776268FD8A20B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%86%8D%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20282px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65223i4EA902EFBCBB8386%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(2)MIFARE%E3%83%8A%E3%83%8E%E3%82%AB%E3%83%BC%E3%83%89%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20553px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65224iF4420F6160D0F9B6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%B3%A8%3A%20testpcsc%20%E3%82%92%E5%86%8D%E5%BA%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65225iAB48369613B9D22D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(3)MIFARE%20EV1%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65226iE5F4A8A95F5BC7A0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65227i215F2CA2557A560A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E6%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%E3%80%81%3CSPAN%3EOpensc%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(1)%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65228iB40141E1D9039173%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(2)MIFARE%20Plus%20x%204K%E3%82%AB%E3%83%BC%E3%83%89(%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AE%E8%BF%91%E3%81%8F%E3%81%A7%E3%80%81opensc-tool%E3%82%92%E5%AE%9F%E8%A1%8C)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65229i1A0903046F6557A6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(3)MIFARE%E3%83%8A%E3%83%8E%E3%82%AB%E3%83%BC%E3%83%89%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65230i8A55B19FB01FF4C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(4)MIFARE%20EV1%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%20style%3D%22width%3A%20553px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F65231i454BB72F91424123%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_17.png%22%20alt%3D%22pastedImage_17.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20right%3B%22%3E%3CSPAN%3ETIC%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%89%E3%83%B3%E3%83%BB%E3%82%B5%E3%83%B3%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20right%3B%22%3E%3CSPAN%3E2018-07-09%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1125050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ENFC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1179831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APN7462%E3%83%87%E3%83%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1179831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81ccid%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20%E9%96%A2%E9%80%A3%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%96%B9%E6%B3%95%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FInstallation-of-Linux-CCID-driver-For-NFC-Reader%2Fta-p%2F1116321%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FInstallation-of-Linux-CCID-driver-For-NFC-Reader%2Fta-p%2F1116321%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E2.%20ccid%20website%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fccid.apdu.fr%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fccid.apdu.fr%2F%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APN7462%E3%83%87%E3%83%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-382481128%22%20id%3D%22toc-hId-1303263185%22%3EHi%20Wigros%20Sun%2C%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--1424973335%22%20id%3D%22toc-hId--504191278%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1062539498%22%20id%3D%22toc-hId-1983321555%22%3EPN7462%20DEMO%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AEWindows%20CE%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95%3C%2FH1%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-09-2018 12:49 AM
更新者:
