1124587_en-US
1124587_en-US
1124587_en-US
3-Phase Hall Sensor PMSM Driver for E-Bike and Sensorless Solution for HV Motor-Based on KE02
Description
A bicycle with an integrated electric motor and a rechargeable battery, making it an eco-friendly, zero-emission vehicle ideal for smart cities. An important feature of an E-Bike is that it must be reliable and can be used for long periods.
Block Diagram
Products
Category Name 1:
Microcontroller
Product 1 URL 1
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/general-purpose-mc...
Product 1 Description 1
The Kinetis KE02 includes a powerful array of analog, communication and timing and control peripherals with specific flash memory size and the pin count. The K02 acts as a low-power, high-robustness, and cost-effective microcontroller with one 6-channel FlexTimer/PWM and two 2-channel FlexTimer/PWM.
Product 2 URL 1
Arm® Cortex®-M4|Kinetis® K64 120 MHz 32-bit MCUs | NXP
Product 2 Description 1
Kinetis® K64-120 MHz, 256 KB SRAM Microcontrollers (MCUs) based on Arm® Cortex®-M4 Core
Category Name 2:
Gate driver
Product 1 URL 1
https://www.nxp.com/products/power-management/motor-and-solenoid-drivers/bldc-h-bridge-stepper/3-pha...
The GD3000 is a gate driver IC for three-phase motor drive applications providing three half-bridge drivers, each capable of driving two N-channel MOSFETs.
Category Name 3:
LED Driver
Product URL 1
https://www.nxp.com/products/power-management/lighting-driver-and-controller-ics/ic-led-controllers/...
Product Description 1
The PCA9955B is an I2C-bus controlled 16-channel constant current LED driver optimized for dimming and blinking 57 mA Red/Green/Blue/Amber (RGBA) LEDs in amusement products. Each LED output has its own 8-bit resolution (256 steps) fixed frequency individual PWM controller that operates at 31.25 kHz with a duty cycle that is adjustable from 0 % to 100 % to allow the LED to be set to a specific brightness value.
Category Name 4:
Logic USB Type-C Configuration Channel
Product URL 1
https://www.nxp.com/products/interfaces/usb-interfaces/usb-type-c-true-plugn-play/usb-pd-phy-and-cc-...
PTN5150 is a small thin low power CC Logic chip supporting the USB Type-C connector application with Configuration Channel (CC) control logic detection and indication functions. The PTN5150 enables USB Type-C connector to be used in both host and device ends of the Type-C cable
Category Name 5:
Current-Limited Power Switch
Product URL 1
https://www.nxp.com/products/power-management/load-switches/usb-pd-and-type-c-current-limited-power-...
The NX5P3290 includes under-voltage lockout, over-temperature protection, and reverse current protection circuits to automatically isolate the switch terminals when a fault condition occurs.
Category Name 6:
Secure
Product 1 URL 1
A71CH | Plug and Trust for IoT | NXP
Plug and Trust - The fast, easy way to deploy secure IoT connections
Category Name 7:
NFC
Product 1 URL 1
PN5180 | Full NFC Forum-compliant frontend IC | NXP
Category Name 8:
GPIO Expander
Product 1 URL 1
PCAL6534 | Level translating GPIO Expander | NXP
Ultra-low-voltage, level translating, 34-bit I2C-bus/SMBus I/O expander
Category Name 8:
NFC smartcard
Product 1 URL 1
https://www.nxp.com/products/rfid-nfc/mifare-hf/mifare-desfire/mifare-desfire-ev2:MIFARE_DESFIRE_EV2...
Secure, contactless multi-application IC with an enhanced feature set for Smart City applications
Related Documentation
Document URL
Title
https://www.nxp.com/docs/en/application-note/AN10439.pdf
Wafer-level chip-scale package
https://www.nxp.com/docs/en/application-note/AN5322.pdf
AN5322, TPMS wheel location introduction and main concepts
Training
Training URL
https://community.nxp.com/docs/DOC-341509
Related Demos from Communities
URL
Kinetis Microcontrollers
MCUXpresso SDK
MCUXpresso Software and Tools
UAV Speed Control with Kinetis KV5x Cortex-M7 MCU and GD3000 Motor Pre-Drivers
Block DiagramsSmart City
No ratings
Version history
Last update:
‎11-20-2025 03:43 AM
Updated by:
