integration of Back-emf method for Sensorless BLDC
1,631 次查看
shey_alex
I have a question regarding the BACK-EMF integration method for sensorless control of BLDC.
How does the threshold value (V_thres) to trigger the commutation is usually calculated? Is it based on the motor parameters or it's trial and error procedure? I haven't found any explanation in application notes about this issue.
Thank you for your answer!
1,612 次查看
pachamatej
have you checked the following AN?
https://www.nxp.com/docs/en/application-note/AN4597.pdf
Please let us know if you need further guidance.
Matej
