Setting up the Target Compilers
4,736 次查看
zhuaoci
What does the following picture mean? What should I do?
4,281 次查看
Daniel_Popa
Step 1: Go to System/Advanced system SettingspastedImage_1.png
Step 2: Select the Environmental Variables
Step 3: Add a new System Variable
Additionally you can check the video embedded in the https://community.nxp.com/thread/451240 at 5'10''
Hope this helps!
6 回复数
4,281 次查看
Daniel_Popa
Hi zhuaoci‌,
I think you have forgot to add the picture.
You can simply copy paste a picture in order to insert it into the message. Otherwise select "Use advanced editor" and the attach button will appear on the bottom of the edition window.
4,281 次查看
zhuaoci
hi Daniel,
      How do I set the target conpiler? what does the follwing picture mean ? I do not understand.
4,282 次查看
Daniel_Popa
Hope this helps!
4,281 次查看
zhuaoci
Dear daniel,
        Thank you very much.Your answer has solved my problem. But I have another question. Why can't I find the model based design for matlab /simulink MBD supporting MPC5604P?Can you give me some information based on model control for 3-Phase PMSM Kit with Qorivva MPC5604P MCU? What I'm using is 3-Phase PMSM Motor Control Development Kit with Qorivva MPC5604P MCU.)$[M[[~Y$3`7}4`Q(UT`HBD.png
4,281 次查看
Daniel_Popa
For the second question the answer is here: https://community.nxp.com/thread/462635#comment-954320
4,281 次查看
zhuaoci
hello daniel,
          Why does the automatically generated code have no project  files?
