S32K3xx Sensorless Example build wasnt complete
yr1205
I was trying to build the example "PMSM Sensorless Field-Oriented Control with Motor Control Blockset™ S32CT" from Simulink into the S32K344. I was able to finish the building process without any Error. The Simulink notified that the build was successful and it was working fine. Then I tried reflashing the same example later, the build was successful, however the blue LED was not turning on.
So, I tried other examples, and still the same issue persists. I am wondering where it went wrong.
yr1205
stefanvlad
Hi @yr1205 ,
What version of the MBDT for S32K3 toolbox are you using?
I do recommend you install the latest NXP Model-Based Design Toolbox for S32K3 version 1.7.0 - Product Release Announcement - NXP Communit...
Second , what board are you using?
If you are using the MCSPTE1AK344 kit, i recommend you follow the Getting started guide
Third, you are using the s32k344_mcb_sensorless_s32ct.mdl ?
If the Blue LED doesn't turn On, there might be a problem with the GD3000 board , not fully inserted into the S32K344-T172 board.
To fix this, you need to press on the GD3000 headers to get better contact into S32K344-T172 board.
Stefan V.
stefanvlad
Hi @yr1205 ,
Stefan V.
%3CLINGO-SUB%20id%3D%22lingo-sub-2184789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3xx%20Sensorless%20Example%20build%20wasnt%20complete%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20was%20trying%20to%20build%20the%20example%20%22%3CFONT%20size%3D%223%22%3EPMSM%20Sensorless%20Field-Oriented%20Control%20with%20Motor%20Control%20Blockset%E2%84%A2%20S32CT%22%20from%20Simulink%20into%20the%20S32K344.%20I%20was%20able%20to%20finish%20the%20building%20process%20without%20any%20Error.%20The%20Simulink%20notified%20that%20the%20build%20was%20successful%20and%20it%20was%20working%20fine.%20Then%20I%20tried%20reflashing%20the%20same%20example%20later%2C%20the%20build%20was%20successful%2C%20however%20the%20blue%20LED%20was%20not%20turning%20on.%20%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%223%22%3ESo%2C%20I%20tried%20other%20examples%2C%20and%20still%20the%20same%20issue%20persists.%20I%20am%20wondering%20where%20it%20went%20wrong.%3C%2FFONT%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3Eyr1205%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3xx%20Sensorless%20Example%20build%20wasnt%20complete%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254447%22%20target%3D%22_blank%22%3E%40yr1205%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EWhat%20version%20of%20the%20MBDT%20for%20S32K3%20toolbox%20are%20you%20using%3F%3C%2FP%3E%0A%3CP%3EI%20do%20recommend%20you%20install%20the%20latest%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FNXP-Model-Based-Design-Toolbox-for-S32K3-version-1-7-0-Product%2Fta-p%2F2177988%22%20target%3D%22_blank%22%3ENXP%20Model-Based%20Design%20Toolbox%20for%20S32K3%20version%201.7.0%20-%20Product%20Release%20Announcement%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ESecond%20%2C%20what%20board%20are%20you%20using%3F%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIf%20you%20are%20using%20the%26nbsp%3B%3CSTRONG%3EMCSPTE1AK344%3C%2FSTRONG%3E%20kit%2C%20i%20recommend%20you%20follow%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fev-ac-charging-solutionss%3AGS-MCSPTE1AK344%3Fsection%3Dplug-it-in%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGetting%20started%20guide%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThird%2C%20you%20are%20using%20the%26nbsp%3Bs32k344_mcb_sensorless_s32ct.mdl%20%3F%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIf%20the%20Blue%20LED%20doesn't%20turn%20On%2C%20there%20might%20be%20a%20problem%20with%20the%20GD3000%20board%20%2C%20not%20fully%20inserted%20into%20the%20S32K344-T172%20board.%3C%2FP%3E%0A%3CP%3ETo%20fix%20this%2C%20you%20need%20to%20press%20on%20the%20GD3000%20headers%20to%20get%20better%20contact%20into%20S32K344-T172%20board.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E
