S32K3xx Sensorless Example build wasnt complete
2,307件の閲覧回数
yr1205
I was trying to build the example "PMSM Sensorless Field-Oriented Control with Motor Control Blockset™ S32CT" from Simulink into the S32K344. I was able to finish the building process without any Error. The Simulink notified that the build was successful and it was working fine. Then I tried reflashing the same example later, the build was successful, however the blue LED was not turning on.
So, I tried other examples, and still the same issue persists. I am wondering where it went wrong.
yr1205
2,242件の閲覧回数
stefanvlad
Hi @yr1205 ,
What version of the MBDT for S32K3 toolbox are you using?
I do recommend you install the latest NXP Model-Based Design Toolbox for S32K3 version 1.7.0 - Product Release Announcement - NXP Communit...
Second , what board are you using?
If you are using the MCSPTE1AK344 kit, i recommend you follow the Getting started guide
Third, you are using the s32k344_mcb_sensorless_s32ct.mdl ?
If the Blue LED doesn't turn On, there might be a problem with the GD3000 board , not fully inserted into the S32K344-T172 board.
To fix this, you need to press on the GD3000 headers to get better contact into S32K344-T172 board.
Stefan V.
2,243件の閲覧回数
stefanvlad
Hi @yr1205 ,
Stefan V.
%3CLINGO-SUB%20id%3D%22lingo-sub-2184789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3xx%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%223%22%3ESimulink%E3%81%8B%E3%82%89S32K344%E3%81%AB%E3%80%8CPMSM%20Sensorless%20Field-Oriented%20Control%20with%20%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%20Blockset%20%E2%84%A2%20S32CT%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%8F%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Simulink%E3%81%8B%E3%82%89%E3%81%AF%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E9%80%9A%E7%9F%A5%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E5%90%8C%E3%81%98%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%86%8D%E5%BA%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E9%9D%92%E8%89%B2LED%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%223%22%3ESO%E3%80%81%E4%BB%96%E3%81%AE%E4%BE%8B%E3%82%82%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%84%E3%81%AF%E3%82%8A%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%B6%9A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%93%E3%81%A7%E9%96%93%E9%81%95%E3%81%88%E3%81%9F%E3%81%AE%E3%81%8B%E6%B0%97%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1205%E5%B9%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3xx%20Sensorless%20Example%20build%20wasnt%20complete%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254447%22%20target%3D%22_blank%22%3E%40yr1205%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ES32K3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E7%94%A8%E3%81%AE%20MBDT%20%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E6%96%B0%E3%81%AE%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FNXP-Model-Based-Design-Toolbox-for-S32K3-version-1-7-0-Product%2Fta-p%2F2177988%22%20target%3D%22_blank%22%3ENXP%20%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%20for%20S32K3%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.7.0%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%20-%20%E8%A3%BD%E5%93%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E7%99%BA%E8%A1%A8%20-%20NXP%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EMCSPTE1AK344%3C%2FSTRONG%3E%E3%82%AD%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fev-ac-charging-solutionss%3AGS-MCSPTE1AK344%3Fsection%3Dplug-it-in%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%85%A5%E9%96%80%E3%82%AC%E3%82%A4%E3%83%89%3C%2FA%3E%E3%81%AB%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E3%20%E7%95%AA%E7%9B%AE%E3%81%AB%E3%80%81%20s32k344_mcb_sensorless_s32ct.mdl%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%9D%92%E8%89%B2%E3%81%AE%20LED%20%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81GD3000%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%20S32K344-T172%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%AE%8C%E5%85%A8%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AA%E3%81%A9%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81GD3000%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81S32K344-T172%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%81%AE%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%82%92%E6%94%B9%E5%96%84%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%83%86%E3%83%95%E3%82%A1%E3%83%B3%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E
