Freemaster recorder error
3,009件の閲覧回数
jtpark
I tested PMSM FOC sensorless control of S12ZVMC.
When I run s/w, I check signal of waveform in oscilloscope but I can't check it in freemaster s/w.
I attached the captured file of recorder error.
Please help for this.
Thanks.
2,797件の閲覧回数
Daniel_Popa
Hi jtpark‌,
Can you try to edit the Recoder Properties and add again the variables to the scope. If you have compiled the application with a different compiler version there might be chance to have a different name for the watch variables and you will need to update it manually.
In other words, if you create a new recorder with a different variable that exists in a scope - does it works ?
Thank you!
