Example MBD Code of BLDC Trapezoidal Sensorless Control S12ZVM
2,269 次查看
tliu
I wonder if there is any example mbd code for BLDC Trapezoidal sensorless control of S12ZVM available. I have some difficulty to implement the trapezoidal sensorless control into the mbd code.
Tony
标记 (2)
2,138 次查看
Daniel_Popa
Hi Tony,
No, we do not have such example - BLDC Sensorless.
What kind of issues are you facing ?
2,138 次查看
tliu
Hi Daniel,
Thanks for the reply. My issue is about to measure the three phase voltage to get the back EMF, since there is a configuration block for GDU which set the GDUPHMUX to 00. I need to have GDUPHMUX changing between 01,10,11 to connect different phase to the adc to get the back EMF. Is there any method to achieve that? Thanks.
Tony
