Bulk Pin Configuration using MBDT S32 CT
778 次查看
suryadevise
Hi Team,
I am working with S32K3 using MBDT (Model-Based Design Toolbox) and S32 Configuration Tools v1.8.
I would like to understand the recommended approach for bulk GPIO / DIO pin configuration.
Current Observation
  • In the Pins Tool, it is not possible to multi-select or bulk-select MCU pins using Ctrl / Shift.
  • Each pin needs to be configured individually through the UI.
  • DIO configuration is derived from the Pins (PORT) configuration, not directly from the DIO driver.
Questions
  1. Is bulk pin configuration (GPIO direction, pull-up/down, initial level) supported in the S32 Configuration Tools v1.8 UI?
  2. If UI-based bulk selection is not supported, what is the recommended and supported workaround?
    • Export Pins to CSV and re-import using Data Manager?
    • Import AUTOSAR ECU configuration (ARXML)?
  3. For MBDT-based projects, is Export Configuration (*.mex) sufficient after updating pin configurations?
  4. Is there any plan to support multi-pin selection or bulk editing in future releases?
Any guidance or best practices from NXP or experienced users would be appreciated.
Thanks & Regards,
Surya S
0 回复数
%3CLINGO-SUB%20id%3D%22lingo-sub-2298525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20MBDT%20S32%20CT%20%E8%BF%9B%E8%A1%8C%E6%89%B9%E9%87%8F%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20MBDT%EF%BC%88%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%EF%BC%89%E5%92%8C%20S32%20Configuration%20Tools%20v1.8%20%E5%A4%84%E7%90%86%20S32K3%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E4%BA%86%E8%A7%A3%E6%89%B9%E9%87%8F%20GPIO%20%2F%20DIO%20%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E7%9A%84%E6%8E%A8%E8%8D%90%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E5%89%8D%E8%A7%82%E5%AF%9F%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%9C%A8%E5%BC%95%E8%84%9A%E5%B7%A5%E5%85%B7%E4%B8%AD%EF%BC%8C%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20Ctrl%20%2F%20Shift%20%E5%A4%9A%E9%80%89%E6%88%96%E6%89%B9%E9%87%8F%E9%80%89%E6%8B%A9%20MCU%20%E5%BC%95%E8%84%9A%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%AF%8F%E4%B8%AA%E5%BC%95%E8%84%9A%E9%83%BD%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%E8%BF%9B%E8%A1%8C%E5%8D%95%E7%8B%AC%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FLI%3E%3CLI%3EDIO%20%E9%85%8D%E7%BD%AE%E6%9D%A5%E8%87%AA%E5%BC%95%E8%84%9A%20(PORT)%20%E9%85%8D%E7%BD%AE%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%9B%B4%E6%8E%A5%E6%9D%A5%E8%87%AA%20DIO%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E9%97%AE%E9%A2%98%3C%2FP%3E%3COL%3E%3CLI%3ES32%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%20v1.8%20%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E6%89%B9%E9%87%8F%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%EF%BC%88GPIO%20%E6%96%B9%E5%90%91%E3%80%81%E4%B8%8A%E6%8B%89%2F%E4%B8%8B%E6%8B%89%E3%80%81%E5%88%9D%E5%A7%8B%E7%94%B5%E5%B9%B3%EF%BC%89%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%94%AF%E6%8C%81%E5%9F%BA%E4%BA%8E%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%E7%9A%84%E6%89%B9%E9%87%8F%E9%80%89%E6%8B%A9%EF%BC%8C%E5%BB%BA%E8%AE%AE%E5%92%8C%E6%94%AF%E6%8C%81%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FLI%3E%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E6%95%B0%E6%8D%AE%E7%AE%A1%E7%90%86%E5%99%A8%E5%B0%86%E5%BC%95%E8%84%9A%E5%AF%BC%E5%87%BA%E4%B8%BA%20CSV%20%E5%B9%B6%E9%87%8D%E6%96%B0%E5%AF%BC%E5%85%A5%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E5%AF%BC%E5%85%A5%20AUTOSAR%20ECU%20%E9%85%8D%E7%BD%AE%20(ARXML)%EF%BC%9F%3C%2FLI%3E%3C%2FUL%3E%3CLI%3E%E5%AF%B9%E4%BA%8E%E5%9F%BA%E4%BA%8E%20MBDT%20%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%9B%B4%E6%96%B0%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E5%90%8E%EF%BC%8C%E5%AF%BC%E5%87%BA%E9%85%8D%E7%BD%AE%20(*.mex)%20%E6%98%AF%E5%90%A6%E8%B6%B3%E5%A4%9F%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E6%9C%AA%E6%9D%A5%E7%89%88%E6%9C%AC%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89%E6%94%AF%E6%8C%81%E5%A4%9A%E9%92%88%E9%80%89%E6%8B%A9%E6%88%96%E6%89%B9%E9%87%8F%E7%BC%96%E8%BE%91%E7%9A%84%E8%AE%A1%E5%88%92%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%81%A9%E6%99%BA%E6%B5%A6%E6%88%96%E6%9C%89%E7%BB%8F%E9%AA%8C%E7%9A%84%E7%94%A8%E6%88%B7%E8%83%BD%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E6%8C%87%E5%AF%BC%E6%88%96%E6%9C%80%E4%BD%B3%E5%AE%9E%E8%B7%B5%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%26amp%3B%20%EF%BC%8C%3CBR%20%2F%3ESurya%20S%3C%2FP%3E%3C%2FLINGO-BODY%3E
