Flash problem on S32k344 (MBDT
Paul50000
I am working on s32k344 EVAL board (HV BMS). The problem is i am not able to flash my code through Simulink. I have created a simple DIO Led Blink model (Just ON the LED). the model was build, even the code is generated, No errors. Still the LED is not ON. When i used S32DS software to blink the LED. The LED is blinking. And then i tried to flash with Simulink. the LED went OFF. Means the program is flashing but the LED is not ON. I double checked the PIN PTA21(RED_LED). What am i doing wrong. I have installed the support packages for debugger and  MBDT Toolbox in MATLAB
SorinIBancila
Did you configure the FS26 to enter debug mode? Otherwise, it will keep resetting the board.
If you are using the X-RD-K344BMU, you can check the included examples in the toolbox to see how to configure Dio, Port components to toggle the LED.
Sorin Bancila
Paul50000
How to configure FS26. I cant find documentation regarding it right now. Please help
SorinIBancila
When powering up the board, keep pressing the SW1 button.
Do not forget to check the examples included in the toolbox, where you have a reference configuration for this board.
Sorin Bancila
Paul50000
i always press the button(SW1) when connecting with PE Micro debugger. But not while flashing or after flashing. I tried with S32 DS software seperately. It flash successfully and LED blinks but when do the same flashing with Simulink then it is not blinking or resetting
SorinIBancila
Alright, so it is not a problem related to FS26.
If possible, can you share your model with me to have a look?
Sorin Bancila
Paul50000
I am sharing my file with you. Its just a basic LED model. Please check whats the issue
Paul50000
I have shared the files. Please reply
%3CLINGO-SUB%20id%3D%22lingo-sub-2294000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlash%20problem%20on%20S32k344%20(MBDT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2294000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20working%20on%20s32k344%20EVAL%20board%20(HV%20BMS).%20The%20problem%20is%20i%20am%20not%20able%20to%20flash%20my%20code%20through%20Simulink.%20I%20have%20created%20a%20simple%20DIO%20Led%20Blink%20model%20(Just%20ON%20the%20LED).%20the%20model%20was%20build%2C%20even%20the%20code%20is%20generated%2C%20No%20errors.%20Still%20the%20LED%20is%20not%20ON.%20When%20i%20used%20S32DS%20software%20to%20blink%20the%20LED.%20The%20LED%20is%20blinking.%20And%20then%20i%20tried%20to%20flash%20with%20Simulink.%20the%20LED%20went%20OFF.%20Means%20the%20program%20is%20flashing%20but%20the%20LED%20is%20not%20ON.%20I%20double%20checked%20the%20PIN%20PTA21(RED_LED).%20What%20am%20i%20doing%20wrong.%20I%20have%20installed%20the%20support%20packages%20for%20debugger%20and%26nbsp%3B%20MBDT%20Toolbox%20in%20MATLAB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20problem%20on%20S32k344%20(MBDT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EDid%20you%20configure%20the%20FS26%20to%20enter%20debug%20mode%3F%20Otherwise%2C%20it%20will%20keep%20resetting%20the%20board.%3C%2FP%3E%0A%3CP%3EIf%20you%20are%20using%20the%20X-RD-K344BMU%3CSTRONG%3E%2C%26nbsp%3B%3C%2FSTRONG%3Eyou%20can%20check%20the%20included%20examples%20in%20the%20toolbox%20to%20see%20how%20to%20configure%20Dio%2C%20Port%20components%20to%20toggle%20the%20LED.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESorin%20Bancila%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20problem%20on%20S32k344%20(MBDT)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EWhen%20powering%20up%20the%20board%2C%20keep%20pressing%20the%20SW1%20button.%3C%2FP%3E%0A%3CP%3EDo%20not%20forget%20to%20check%20the%20examples%20included%20in%20the%20toolbox%2C%20where%20you%20have%20a%20reference%20configuration%20for%20this%20board.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESorin%20Bancila%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20problem%20on%20S32k344%20(MBDT)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20to%20configure%20FS26.%20I%20cant%20find%20documentation%20regarding%20it%20right%20now.%20Please%20help%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20problem%20on%20S32k344%20(MBDT)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAlright%2C%20so%20it%20is%20not%20a%20problem%20related%20to%20FS26.%3C%2FP%3E%0A%3CP%3EIf%20possible%2C%20can%20you%20share%20your%20model%20with%20me%20to%20have%20a%20look%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESorin%20Bancila%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20problem%20on%20S32k344%20(MBDT)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei%20always%20press%20the%20button(SW1)%20when%20connecting%20with%20PE%20Micro%20debugger.%20But%20not%20while%20flashing%20or%20after%20flashing.%20I%20tried%20with%20S32%20DS%20software%20seperately.%20It%20flash%20successfully%20and%20LED%20blinks%20but%20when%20do%20the%20same%20flashing%20with%20Simulink%20then%20it%20is%20not%20blinking%20or%20resetting%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20problem%20on%20S32k344%20(MBDT)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20sharing%20my%20file%20with%20you.%20Its%20just%20a%20basic%20LED%20model.%20Please%20check%20whats%20the%20issue%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20problem%20on%20S32k344%20(MBDT)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20shared%20the%20files.%20Please%20reply%3C%2FP%3E%3C%2FLINGO-BODY%3E
