Bulk Pin Configuration using MBDT S32 CT
suryadevise
Hi Team,
I am working with S32K3 using MBDT (Model-Based Design Toolbox) and S32 Configuration Tools v1.8.
I would like to understand the recommended approach for bulk GPIO / DIO pin configuration.
Current Observation
  • In the Pins Tool, it is not possible to multi-select or bulk-select MCU pins using Ctrl / Shift.
  • Each pin needs to be configured individually through the UI.
  • DIO configuration is derived from the Pins (PORT) configuration, not directly from the DIO driver.
Questions
  1. Is bulk pin configuration (GPIO direction, pull-up/down, initial level) supported in the S32 Configuration Tools v1.8 UI?
  2. If UI-based bulk selection is not supported, what is the recommended and supported workaround?
    • Export Pins to CSV and re-import using Data Manager?
    • Import AUTOSAR ECU configuration (ARXML)?
  3. For MBDT-based projects, is Export Configuration (*.mex) sufficient after updating pin configurations?
  4. Is there any plan to support multi-pin selection or bulk editing in future releases?
Any guidance or best practices from NXP or experienced users would be appreciated.
Thanks & Regards,
Surya S
%3CLINGO-SUB%20id%3D%22lingo-sub-2298525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBulk%20Pin%20Configuration%20using%20MBDT%20S32%20CT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Team%2C%3C%2FP%3E%3CP%3EI%20am%20working%20with%20S32K3%20using%20MBDT%20(Model-Based%20Design%20Toolbox)%20and%20S32%20Configuration%20Tools%20v1.8.%3CBR%20%2F%3EI%20would%20like%20to%20understand%20the%20recommended%20approach%20for%20bulk%20GPIO%20%2F%20DIO%20pin%20configuration.%3C%2FP%3E%3CP%3ECurrent%20Observation%3C%2FP%3E%3CUL%3E%3CLI%3EIn%20the%20Pins%20Tool%2C%20it%20is%20not%20possible%20to%20multi-select%20or%20bulk-select%20MCU%20pins%20using%20Ctrl%20%2F%20Shift.%3C%2FLI%3E%3CLI%3EEach%20pin%20needs%20to%20be%20configured%20individually%20through%20the%20UI.%3C%2FLI%3E%3CLI%3EDIO%20configuration%20is%20derived%20from%20the%20Pins%20(PORT)%20configuration%2C%20not%20directly%20from%20the%20DIO%20driver.%3C%2FLI%3E%3C%2FUL%3E%3CP%3EQuestions%3C%2FP%3E%3COL%3E%3CLI%3EIs%20bulk%20pin%20configuration%20(GPIO%20direction%2C%20pull-up%2Fdown%2C%20initial%20level)%20supported%20in%20the%20S32%20Configuration%20Tools%20v1.8%20UI%3F%3C%2FLI%3E%3CLI%3EIf%20UI-based%20bulk%20selection%20is%20not%20supported%2C%20what%20is%20the%20recommended%20and%20supported%20workaround%3F%3C%2FLI%3E%3CUL%3E%3CLI%3EExport%20Pins%20to%20CSV%20and%20re-import%20using%20Data%20Manager%3F%3C%2FLI%3E%3CLI%3EImport%20AUTOSAR%20ECU%20configuration%20(ARXML)%3F%3C%2FLI%3E%3C%2FUL%3E%3CLI%3EFor%20MBDT-based%20projects%2C%20is%20Export%20Configuration%20(*.mex)%20sufficient%20after%20updating%20pin%20configurations%3F%3C%2FLI%3E%3CLI%3EIs%20there%20any%20plan%20to%20support%20multi-pin%20selection%20or%20bulk%20editing%20in%20future%20releases%3F%3C%2FLI%3E%3C%2FOL%3E%3CP%3EAny%20guidance%20or%20best%20practices%20from%20NXP%20or%20experienced%20users%20would%20be%20appreciated.%3C%2FP%3E%3CP%3EThanks%20%26amp%3B%20Regards%2C%3CBR%20%2F%3ESurya%20S%3C%2FP%3E%3C%2FLINGO-BODY%3E
