Bulk Pin Configuration using MBDT S32 CT
794件の閲覧回数
suryadevise
Hi Team,
I am working with S32K3 using MBDT (Model-Based Design Toolbox) and S32 Configuration Tools v1.8.
I would like to understand the recommended approach for bulk GPIO / DIO pin configuration.
Current Observation
  • In the Pins Tool, it is not possible to multi-select or bulk-select MCU pins using Ctrl / Shift.
  • Each pin needs to be configured individually through the UI.
  • DIO configuration is derived from the Pins (PORT) configuration, not directly from the DIO driver.
Questions
  1. Is bulk pin configuration (GPIO direction, pull-up/down, initial level) supported in the S32 Configuration Tools v1.8 UI?
  2. If UI-based bulk selection is not supported, what is the recommended and supported workaround?
    • Export Pins to CSV and re-import using Data Manager?
    • Import AUTOSAR ECU configuration (ARXML)?
  3. For MBDT-based projects, is Export Configuration (*.mex) sufficient after updating pin configurations?
  4. Is there any plan to support multi-pin selection or bulk editing in future releases?
Any guidance or best practices from NXP or experienced users would be appreciated.
Thanks & Regards,
Surya S
0 返答(返信)
%3CLINGO-SUB%20id%3D%22lingo-sub-2298525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMBDT%20S32%20CT%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%90%E3%83%AB%E3%82%AF%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%81%E3%83%BC%E3%83%A0%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81MBDT%20(%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9)%20%E3%81%A8%20S32%20%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%20v1.8%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20S32K3%20%E3%82%92%E6%93%8D%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%83%AB%E3%82%AF%20GPIO%20%2F%20DIO%20%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A6%B3%E6%B8%AC%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%94%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81Ctrl%20%2F%20Shift%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20MCU%20%E3%83%94%E3%83%B3%E3%82%92%E8%A4%87%E6%95%B0%E9%81%B8%E6%8A%9E%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%80%E6%8B%AC%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%90%84%E3%83%94%E3%83%B3%E3%81%AF%20UI%20%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E5%80%8B%E5%88%A5%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3EDIO%20%E6%A7%8B%E6%88%90%E3%81%AF%E3%80%81DIO%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%94%E3%83%B3%20(%E3%83%9D%E3%83%BC%E3%83%88)%20%E6%A7%8B%E6%88%90%E3%81%8B%E3%82%89%E6%B4%BE%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%B3%AA%E5%95%8F%3C%2FP%3E%3COL%3E%3CLI%3ES32%20%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%20v1.8%20UI%20%E3%81%A7%E3%81%AF%E3%80%81%E3%83%90%E3%83%AB%E3%82%AF%20%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%20(GPIO%20%E6%96%B9%E5%90%91%E3%80%81%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%2F%E3%83%80%E3%82%A6%E3%83%B3%E3%80%81%E5%88%9D%E6%9C%9F%E3%83%AC%E3%83%99%E3%83%AB)%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3EUI%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E4%B8%80%E6%8B%AC%E9%81%B8%E6%8A%9E%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CUL%3E%3CLI%3E%E3%83%94%E3%83%B3%E3%82%92%20CSV%20%E3%81%AB%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%86%8D%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3EAUTOSAR%20ECU%20%E6%A7%8B%E6%88%90%20(ARXML)%20%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FUL%3E%3CLI%3EMBDT%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%20(*.mex)%20%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3EFUTURE%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E8%A4%87%E6%95%B0%E3%83%94%E3%83%B3%E3%81%AE%E9%81%B8%E6%8A%9E%E3%82%84%E4%B8%80%E6%8B%AC%E7%B7%A8%E9%9B%86%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FOL%3E%3CP%3ENXP%20%E3%81%BE%E3%81%9F%E3%81%AF%E7%B5%8C%E9%A8%93%E8%B1%8A%E5%AF%8C%E3%81%AA%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%82%84%E3%83%99%E3%82%B9%E3%83%88%20%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%82%3CBR%20%2F%3E%E3%82%B9%E3%83%BC%E3%83%AA%E3%83%A4S%3C%2FP%3E%3C%2FLINGO-BODY%3E
