upload a file through the webserver
1,427 次查看
Microfelix
hello
I'm testing a card "TWR-K60" with CodeWarrior and I'd like to upload a file through the webserver. Is there an example? Maybe using the FTP-server? Can you explain how can I do?
thanks Maurizio
1,200 次查看
DavidS
Hi Maurizio,
There are several example in the Freescale MQX3.7 release that have ftp capability.
Freescale MQX 3.7\mfs\examples\mfs_ftp
This is a good example.
You can FTP files to a USB stick connected to the TWRSER card.
Hope this helps.
David
1,201 次查看
DavidS
Hi Maurizio,
Hope this helps.
David
