mqx support on ssh
mqx support on ssh
1,526 次查看
sannyfrancis
Kindly let me know of the mqx support for ssh.
Has anyone tried porting openssh on to mqx?
Thanks in advance
1,176 次查看
danielchen
Hi Sanny:
We have included third party Wolfssl library code for TLS protocl.
Please refer to the SSL manual
https://www.wolfssl.com/wolfSSL/Docs-wolfssl-manual-toc.html
Here you can see the patch for cyassl
Now Available: MQX 4.2.0.1 Patch
1,176 次查看
sannyfrancis
Thanks for the quick reply......
You are talking of SSL.
I would like to know if there are any support for SSH in MQX?
1> I have come across Mocana NanoSSH.Is there any supporting login examples sources for using NanoSSH / Documentation on the same? Can this be easily integrated? Could you shed more details on Mocana NanoSSH?
2> Since we are using MQX 3.1, What other steps would be needed from my end to integrate NanoSSH?
1,176 次查看
DavidS
Hi Sanny,
Short answer is Mocana support for Kinetis was deprecated several years ago.
The WolfSSL is only SSL and currently does not support SSH.  Ping them to see if they have SSH on the roadmap.
David
