Switch to blocked MQX task in debugger
rhermes
I would like to switch to a blocked MQX task stack frame so I can see
1. what specific item is blocking the task
2. the execution tree that led to the blocking call.
Is there a way to do this from the KDS 3.0 debugger?
Thank You,
Randy Hermes
Carlos_Mendoza
Hi Randy,
Unfortunately the thread aware capability in KDS does not support this, the developers are already working on a Thread Aware plug-in for Kinetis Design Studio but there is no release date yet.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
