how to make SSL socket in FRDMK64 (ethernet to serial)
1,344 次查看
sudhakarp
HI,
     i want to implement SSL socket in frdmk64-ethernet to serial project. i am using KDS 2.0 and ksdk 1.1.0 example.
anyone can guide me. if any exact SSL document available for K64 controller?. i mean how to initialize and how to use API function
and all... if any one send example code means i can easily understand.
thanks and regards,
sudhakar p
857 次查看
soledad
Hello Sudhakar,
Please check the below link
Now Available: CyaSSL for MQX RTCS
Sol
857 次查看
sudhakarp
hi,
is possible to interface CyaSSL for Kinetis SDK v1.2.0 in "KSDK 1.1.0".
because i am getting only "CyaSSL for Kinetis SDK v1.2.0 " download option. can you give exact link for v1.1.0 and also how to build that example project.
thanks and regards,
sudhakar p
857 次查看
soledad
Please check the Mac's answer in the below link
Sol
