lnosys error in frdmk64f120 controller
1,087件の閲覧回数
sudhakarp
Contributor V
hi,
     i tried ethernet_to_serial example code but its showing "cannot find lnosys error". i build all the library. i am using KDS2.0 IDE and
KSDK 1.2.0 example project. i think i am missing some library can you give solution for this.
NOTE:
previously i used KSDK 1.1.0 its working fine. after i updated to KSDK 1.2.0.
regards,
sudhakar p
959件の閲覧回数
soledad
Hello sudhakar,
Please check the attached video.
I hope this helps
Sol
