The debugger is not connected to PE device
1,075 次查看
davidzhou
I am a newbie on freescale. Just installed MQX and Code Worrier (Ver10.6.4.) I imported Hello and Hello2 projects. Compiled and be able to debug into the program. But the debugger crashes the _SET_KERNEL_DATA inside the call _mqx( (MQX_INITIALIZATION_STRUCT_PTR) &MQX_init_struct );
The hello2_twrk60f120m is debugged as flash_debug with Target settings as TWRK60F120M_OSJTAG.
What is wrong?
Thank you,
David
949 次查看
davidzhou
This may be caused by either no license or MQX plugin was not installed. After installed MQX plugin and with activated license key, the problem runs away.
950 次查看
davidzhou
