CodeWarrior 10.x & MQX Documentation?
2,035 次查看
BenG
I normally use IAR Embedded Workbench, but I want to experiment with using Code Warrior. I'm not overly familiar with the Eclipse IDE/Interface but I can do some basic development with it.
Is there any documentation available which covers using MQX 3.x with CodeWarrior 10.x?
I can find documentation for  MQX 3.8 and CW 10.x, but no documentation that covers both together. The MQX documentation that refers to CodeWarrior refers to the "classic" version (i.e. 6.x/7.x) (e.g. AN3905) which is obviously significantly different from the Eclipse interface used in 10.x,
1,720 次查看
LuisCasado
Have you seen this doc? It is part of MQX3.7 docs
1,721 次查看
LuisCasado
1,720 次查看
BenG
Cheers Luis,
That's exactly what I was after.
