MPC574xP - How to use the quad-page programming for flash memory c55fmc
1,609 次查看
fredericleloir
Do you have an application note or an user guide or an example that describes how to use the quad page programming (1024 bits) for the MPC574xP family ?
For information, the embedded flash memory is C55fmc.
Thx for you help.
Frederic
1,398 次查看
lukaszadrapa
Example MPC5748G Flash RW
Example MPC5748G Flash RW SSD
it is written for MPC5748G but the procedure is the same. First example shows how to program the flash using pure C code, second example is doing the same but SSD drivers (mentioned by Aleksandar above) are used.
Lukas
1,398 次查看
alexvinchev
Contributor V
fredericleloir, I believe easiest way for you is to use SSD http://cache.nxp.com/files/product/software/C55_JDP_SSD.exe
There is nice user manual when you install it (SSD_C55_UM_v1.1.pdf).
