MPC5748G DEVKIT CLKOUT
1,649 次查看
antleite2001
Hi All
I am trying to route CLKOUT_0 and CLKOUT_1 to PG7 and PG6 with no success.
Scopemeter connected between J3.13 (GND) and J3.14 (PG[6]) are in 3v3
Scopemeter connected between J3.13 (GND) and J3.16 (PG[7]) are in 3v3
Components
clock_manager Tab CLKOUT CLKOUT0 and CLKOUT1 are enabled
pin_mux PG[6] routed to Platform/clkout/1
PG[7] routed to Platform/clkout/0
Thanks in advance
Antonio Leite
1,616 次查看
davidtosenovjan
Hi, have you checked pad configuration in the debugger whether it fulfills setting defined in the I/O excel?
Also it is needed to have configured CLKOUT clock source and configured CLKOUT divider(MC_CGM_AC6_SC and MC_CGM_CLKOUT1_SC).
1,617 次查看
davidtosenovjan
