The difference between spc5606bk0 and spc5606bk1, except that the wafer factory is different, can the difference of mask Rev be found in PDF? Can spc5606bk0 and spc5606bk1 be used instead of each other?
Solved! Go to Solution.
There are significant differences between these two devices and they are covered in the following appnote:
https://www.nxp.com/docs/en/application-note/AN4477.pdf
Note that
SPC5606BF = mask 1M03Y
SPC5606BK = mask 01N3E
MPC5606/5BK are derivatives of Bolero1M device whilst MPC5607/6/5BF are derivatives of Bolero1.5M device.
MPC5606BK datasheet:
http://cache.freescale.com/files/32bit/doc/data_sheet/MPC5606B.pdf
MPC5607BF datasheet:
http://cache.freescale.com/files/32bit/doc/data_sheet/MPC5607B.pdf
Note that
Do you mean SPC5606BK0.. and SPC5606BF1... correct? As I know there is no version BK1
