MPC5741P How to create a linker for Code Flash blocks
1,977件の閲覧回数
tanveerahmed
@Hi ,
We are planning to use MPC5741P controller in our project. I went through the reference manual and found that memory block with below address
1. 0x010C0000 to 0x010FFFFF
2. 0x01140000 to 0x0117FFFF
3. 0x011C0000 to 0x011FFFFF
is not available for MPC5741P controller. But there are two blocks in between 0x01100000 to 0x0113FFFF and 0x01180000 to 0x011BFFFF which should be available for MPC5741P controller.
But i am finding it difficult how to create a linker file to include the blocks 0x01100000 to 0x0113FFFF and 0x01180000 to 0x011BFFFF as internal flash.
Can you please share any example for this use case.
Tanveer
2 返答(返信)
1,821件の閲覧回数
ybb34713
Have you solved the problem yet?
1,821件の閲覧回数
tanveerahmed
@David Tosenovjan can you please help for this topic.
