I want to trigger the MCU Functional Long Reset with the following statement:
/* software reset */
ME.MCTL.R = 0x00005AF0;
ME.MCTL.R = 0x0000A50F;
The Reset action was executed successfully,but, I found that it took more than 5 seconds for the CPU restart again,
I don't know what caused it to take so long time. Anybody had a problem like this?
Is there a way to make the CPU reset faster?I hope to complete the reset in 2 seconds.
it doesn't sound realistic, the reset sequence is much shorter:
What is connected to reset pin?
Lukas
Hi Lukas,
Thank you for your answer,I use the current consumed to watch if the CPU is restarted finish.
I have ran the time test again,In fact, the CPU has completed the restart quickly,
Because the peripheral circuit power supply is not completed, so CPU Restart feels slow.
Thanks for your explanation.
