MPC5566 EMIOS SAOC mode
2,650件の閲覧回数
EmilyZhou8
I am setting EMIOS 17 to work as SAOC mode channel which uses bus C driven by EMIOS 8. However, SAOC mode is not working. Could you please help to check my code?
Thank you very much!
Emily
#include "MPC5566.h"
/************ PWM_Period and PWM_Frequence should be changed together ************/
/* Define PWM period Counter value */
#define PWM_Period 16
#define FS_GPIO_EMIOS17 196
#define Commutation_Time_Channel FS_GPIO_EMIOS17
void initSysclk (void) {
FMPLL.SYNCR.B.LOLRE = 0; /* 0: ignore loss of lock - reset not asserted. */
FMPLL.SYNCR.B.LOLIRQ = 0; /* 0: ignore loss of lock - interrupt not requested */
FMPLL.SYNCR.B.PREDIV = 1; /* 1: use incoming OSC 8MHz / 2 = 4 MHz */
FMPLL.SYNCR.B.MFD = 28; /* 28: VCO = 4 * (28+4) = 128 MHz */
FMPLL.SYNCR.B.RFD = 1; /* 1: divide by 2, Fsys = VCO / (2^1=2) = 64MHz */
while(FMPLL.SYNSR.B.LOCK != 1){} /* Wait for FMPLL to Lock */
FMPLL.SYNCR.B.RFD = 0; /* 0: divide by 1, Fsys = VCO / (2^0=1) = 128MHz */
void initEMIOS(void) {
EMIOS.MCR.B.GPRE= 7; /* Divide 128 MHz sysclk by 7+1 = 8 for 16MHz eMIOS clk*/ //EMIOS.MCR.B.GPRE= 63; /* Divide 64 MHz sysclk by 63+1 = 64 for 1MHz eMIOS clk*/
EMIOS.MCR.B.ETB = 0; /* External time base is disabled; Ch 23 drives ctr bus A */
EMIOS.MCR.B.GPREN = 1; /* Enable eMIOS clock */
EMIOS.MCR.B.GTBE = 1; /* Enable global time base */
EMIOS.MCR.B.FRZ = 1; /* Enable stopping channels when in debug mode */
void initEMIOSch8(void) { /* EMIOS CH 8: Modulus Up Counter */
EMIOS.CH[8].CADR.R = PWM_Period - 1; /* Period will be 15+1 = 16 clocks (1 MHz) */
EMIOS.CH[8].CCR.B.MODE = 0x10; /* MPC555x: Modulus Counter (MC), internal clock */
EMIOS.CH[8].CCR.B.BSL = 0x3; /* Use internal counter */
EMIOS.CH[8].CCR.B.UCPRE=0; /* Set channel prescaler to divide by 1 */
EMIOS.CH[8].CCR.B.FREN = 1; /* Freeze channel counting when in debug mode */
EMIOS.CH[8].CCR.B.UCPREN = 1; /* Enable prescaler; uses default divide by 1 */
void initEMIOSch17(void) {
uint8_t EMIOS_Channel_Output;
EMIOS_Channel_Output = Commutation_Time_Channel-179; /* Convert to EMIOS channel number compatible with EMIOS struct in MPC5566.h */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.MODE = 0x3; /* MPC555x: Mode is Single action output compare */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.BSL = 0x1; /* Use bus C */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.UCPRE = 0; /* Set channel prescaler to divide by 1 */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.FREN = 1; /* Stop (freeze) channel registers when in debug mode */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.UCPREN = 1; /* Enable prescaler; uses default divide by 1 */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.DMA = 0; /* FLAG assigned to Interrupt request */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.EDSEL = 1; /* Both edges triggering */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.FCK = 0; /* Filter clock select: EMIOS clock */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.IF = 0x1; /* Input filter: 8 filter clock periods */
EMIOS.CH[EMIOS_Channel_Output].CCR.B.FEN = 1; /* Flag enables interrupt */
SIU.PCR[Commutation_Time_Channel].R = 0x0E00; /* MPC555x: Initialize pad for eMIOS output */
void main (void) {
volatile uint32_t i = 0; /* Dummy idle counter */
uint32_t NextCmtPeriod=1000;
initSysclk(); /* Set sysclk = 128MHz running from PLL */
initEMIOS(); /* Initialize eMIOS to provide 16 MHz clock to channels */
initEMIOSch8(); /* Initialize eMIOS channel 8 as modulus counter*/
initEMIOSch17(); /* Initialize eMIOS channel 17 as SAOC, using ch 8 as time base */
while (1)
{i++;
EMIOS.CH[17].CADR.R = EMIOS.CH[8].CCNTR.R + NextCmtPeriod;
while(EMIOS.CH[17].CSR.B.FLAG != 1)
NextCmtPeriod=NextCmtPeriod+2000;
EMIOS.CH[17].CSR.B.FLAG = 1;
2,604件の閲覧回数
PetrS
yes, correct.
BR, Petr
4 返答(返信)
2,615件の閲覧回数
PetrS
if you want to use local counter bus for ch17, then ch16 (counter us D) have to be configured, not ch8 you have
BR, Petr
2,606件の閲覧回数
EmilyZhou8
Hi Peter,
Thanks for your reply. I am wondering if I use EMIOS Chanel 16 to set bus D, SAOC of EMIOS Channel 17 can work only if EMIOS.CH[16].CADR.R>=EMIOS.CH[17].CADR.R?
Emily
2,605件の閲覧回数
PetrS
yes, correct.
BR, Petr
2,568件の閲覧回数
EmilyZhou8
Thanks a lot!
%3CLINGO-SUB%20id%3D%22lingo-sub-1924060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5566%20EMIOS%20SAOC%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1924060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EEMIOS%2017%E3%82%92%E3%80%81EMIOS%208%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%A7%86%E5%8B%95%E3%81%95%E3%82%8C%E3%82%8B%E3%83%90%E3%82%B9C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BSAOC%E3%83%A2%E3%83%BC%E3%83%89%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81SAOC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%9F%E3%83%AA%E3%83%BC%3C%2FP%3E%3CP%3E%23include%E3%80%8CMPC5566.h%E3%80%8D%3C%2FP%3E%3CP%3E%2F************%20PWM_Period%20%E3%81%A8%20PWM_Frequence%20%E3%81%AF%E4%B8%80%E7%B7%92%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20************%2F%3CBR%20%2F%3E%2F*%20PWM%20%E6%9C%9F%E9%96%93%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E5%80%A4%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%23define%20PWM_Period%2016%3CBR%20%2F%3E%23define%20FS_GPIO_EMIOS17%20196%3CBR%20%2F%3E%23define%20Commutation_Time_Channel%20FS_GPIO_EMIOS17%3C%2FP%3E%3CP%3Evoid%20initSysclk%20(void)%20%7B%3CBR%20%2F%3E%3CBR%20%2F%3EFMPLL%E3%81%A7%E3%81%99%E3%80%82SYNCR%E3%81%A7%E3%81%99%E3%80%82B.LOLRE%20%3D%200%3B%2F*%200%3A%20%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E6%90%8D%E5%A4%B1%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%20-%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82*%2F%3CBR%20%2F%3EFMPLL%E3%81%A7%E3%81%99%E3%80%82SYNCR%E3%81%A7%E3%81%99%E3%80%82B.LOLIRQ%20%3D%200%3B%2F*%200%3A%20%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E6%90%8D%E5%A4%B1%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%20-%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AF%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3CBR%20%2F%3EFMPLL%E3%81%A7%E3%81%99%E3%80%82SYNCR%E3%81%A7%E3%81%99%E3%80%82B.PREDIV%20%3D%201%3B%2F*%201%3A%E5%85%A5%E5%8A%9BOSC%E3%82%92%E4%BD%BF%E7%94%A88MHz%20%2F%202%20%3D%204%20MHz%20*%2F%3CBR%20%2F%3EFMPLL%E3%81%A7%E3%81%99%E3%80%82SYNCR%E3%81%A7%E3%81%99%E3%80%82B.MFD%20%3D%2028%3B%2F*%2028%3A%20VCO%20%3D%204%20*%20(28%2B4)%20%3D%20128%20MHz%20*%2F%3CBR%20%2F%3EFMPLL%E3%81%A7%E3%81%99%E3%80%82SYNCR%E3%81%A7%E3%81%99%E3%80%82B.RFD%20%3D%201%3B%2F*%201%3A2%E3%81%A7%E5%89%B2%E3%82%8B%E3%80%81Fsys%20%3D%20VCO%20%2F(2%20%5E%201%20%3D%202)%3D%2064MHz%20*%2F%3CBR%20%2F%3E%E4%B8%80%E6%96%B9(FMPLL.SYNSR%E3%81%A7%E3%81%99%E3%80%82B.LOCK%20!%3D%201)%7B%7D%20%2F*%20FMPLL%E3%81%8C%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E3%81%A4%20*%2F%3CBR%20%2F%3EFMPLL%E3%81%A7%E3%81%99%E3%80%82SYNCR%E3%81%A7%E3%81%99%E3%80%82B.RFD%20%3D%200%3B%2F*%200%3A%201%20%E3%81%A7%E9%99%A4%E7%AE%97%E3%80%81Fsys%20%3D%20VCO%20%2F%20(2%5E0%3D1)%20%3D%20128MHz%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E3%83%9C%E3%82%A4%E3%83%89%20initEMIOS(%E3%83%9C%E3%82%A4%E3%83%89)%20%7B%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82MCR%E3%81%A7%E3%81%99%E3%80%82B.GPRE%3D%207%3B%2F*%2016MHz%20eMIOS%20clk%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20128%20MHz%20sysclk%20%E3%82%92%207%2B1%20%3D%208%20%E3%81%A7%E9%99%A4%E7%AE%97*%2F%20%2F%2FEMIOS.MCR%E3%81%A7%E3%81%99%E3%80%82B.GPRE%3D%2063%3B%2F*%201MHz%20eMIOS%20clk%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%8164MHz%20sysclk%20%E3%82%92%2063%2B1%20%3D%2064%20%E3%81%A7%E9%99%A4%E7%AE%97*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82MCR%E3%81%A7%E3%81%99%E3%80%82B.ETB%20%3D%200%3B%2F*%20%E5%A4%96%E9%83%A8%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82Ch%2023%20%E3%81%AF%20ctr%20%E3%83%90%E3%82%B9%20A%20%E3%82%92%E9%A7%86%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82MCR%E3%81%A7%E3%81%99%E3%80%82B.GPREN%20%3D%201%3B%2F*%20eMIOS%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82MCR%E3%81%A7%E3%81%99%E3%80%82B.GTBE%20%3D%201%3B%2F*%20%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82MCR%E3%81%A7%E3%81%99%E3%80%82B.FRZ%20%3D%201%3B%2F*%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E5%81%9C%E6%AD%A2%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Evoid%20initEMIOSch8(void)%20%7B%20%2F*%20EMIOS%20CH%208%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%A9%E3%82%B9%E3%82%A2%E3%83%83%E3%83%97%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B8%5D%E3%80%82CADR%E3%81%A7%E3%81%99%E3%80%82R%20%3D%20PWM_Period%20-%201%3B%2F*%20%E5%91%A8%E6%9C%9F%E3%81%AF%2015%2B1%20%3D%2016%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20(1%20MHz)%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B8%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.%E3%83%A2%E3%83%BC%E3%83%89%20%3D%200x10%3B%2F*%20MPC555x%3A%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%A9%E3%82%B9%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF(MC)%E3%80%81%E5%86%85%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B8%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.BSL%20%3D%200x3%3B%2F*%20%E5%86%85%E9%83%A8%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B8%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.UCPRE%3D0%3B%2F*%20%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%201%20%E3%81%A7%E9%99%A4%E7%AE%97%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B8%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.FREN%20%3D%201%3B%2F*%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E6%99%82%E3%81%AE%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B8%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.UCPREN%20%3D%201%3B%2F*%20%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E9%99%A4%E7%AE%97%E3%82%921%E3%81%A7%E9%99%A4%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Evoid%20initEMIOSch17(%E3%83%9C%E3%82%A4%E3%83%89)%20%7B%3CBR%20%2F%3Euint8_t%20EMIOS_Channel_Output%3B%3CBR%20%2F%3E%3CBR%20%2F%3EEMIOS_Channel_Output%20%3D%20Commutation_Time_Channel-179%3B%2F*%20MPC5566.h%20%E3%81%AE%20EMIOS%20struct%20%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%20EMIOS%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E7%95%AA%E5%8F%B7%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.%E3%83%A2%E3%83%BC%E3%83%89%20%3D%200x3%3B%2F*%20MPC555x%3A%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E5%87%BA%E5%8A%9B%E6%AF%94%E8%BC%83%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.BSL%20%3D%200x1%3B%2F*%20%E3%83%90%E3%82%B9C%E3%82%92%E4%BD%BF%E7%94%A8%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.UCPRE%20%3D%200%3B%2F*%20%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%201%20%E3%81%A7%E9%99%A4%E7%AE%97%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.FREN%20%3D%201%3B%2F*%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E6%99%82%E3%81%AB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E5%81%9C%E6%AD%A2%20(%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA)%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.UCPREN%20%3D%201%3B%2F*%20%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E9%99%A4%E7%AE%97%E3%82%921%E3%81%A7%E9%99%A4%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.DMA%20%3D%200%3B%2F*%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A6%81%E6%B1%82%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%83%95%E3%83%A9%E3%82%B0%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.%E3%82%A8%E3%83%89%E3%82%BB%E3%83%AB%20%3D%201%3B%2F*%20%E4%B8%A1%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AE%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.FCK%20%3D%200%3B%2F*%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E9%81%B8%E6%8A%9E%3A%20EMIOS%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.IF%3D0x1%3B%2F*%20%E5%85%A5%E5%8A%9B%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%3A%208%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%9C%9F%20*%2F%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5BEMIOS_Channel_Output%5D%E3%80%82CCR%E3%81%A7%E3%81%99%E3%80%82B.FEN%20%3D%201%3B%2F*%20%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3ESIU%E3%81%A7%E3%81%99%E3%80%82PCR%5BCommutation_Time_Channel%5D%E3%80%82R%20%3D%200x0E00%3B%2F*%20MPC555x%3A%20eMIOS%20%E5%87%BA%E5%8A%9B%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%91%E3%83%83%E3%83%89%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E3%83%9C%E3%82%A4%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3(%E3%83%9C%E3%82%A4%E3%83%89)%7B%3CBR%20%2F%3E%E6%8F%AE%E7%99%BA%E6%80%A7uint32_t%20i%20%3D%200%3B%2F*%20%E3%83%80%E3%83%9F%E3%83%BC%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20*%2F%3CBR%20%2F%3Euint32_t%20NextCmtPeriod%3D1000%3B%3CBR%20%2F%3EinitSysclk()%3B%2F*%20PLL%E3%81%8B%E3%82%89sysclk%20%3D%20128MHz%E3%81%A8%E8%A8%AD%E5%AE%9A%20*%2F%3CBR%20%2F%3EinitEMIOS()%3B%2F*%20eMIOS%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%2016%20MHz%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%8F%90%E4%BE%9B%20*%2F%3CBR%20%2F%3EinitEMIOSch8()%3B%2F*%20eMIOS%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%208%20%E3%82%92%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%A9%E3%82%B9%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%A8%E3%81%97%E3%81%A6%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99*%2F%3CBR%20%2F%3EinitEMIOSch17()%3B%2F*%20eMIOS%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%2017%20%E3%82%92%20SAOC%20%E3%81%A8%E3%81%97%E3%81%A6%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%208%20%E3%82%92%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E(1)%E3%81%AA%E3%81%8C%E3%82%89%3CBR%20%2F%3E%7Bi%2B%2B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B17%5D%E3%80%82CADR%E3%81%A7%E3%81%99%E3%80%82R%20%3D%20%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B8%5D%E3%80%82CCNTR%E3%81%A7%E3%81%99%E3%80%82R%20%2B%20NextCmtPeriod%3B%3CBR%20%2F%3E%E4%B8%80%E6%96%B9(%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B17%5D%E3%80%82CSR(%E7%A4%BE%E4%BC%9A%E8%B2%A2%E7%8C%AE%E6%B4%BB%E5%8B%95)%E3%80%82B.%E3%83%95%E3%83%A9%E3%82%B0%20!%3D%201)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3ENextCmtPeriod%3DNextCmtPeriod%2B2000%3B%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%82%AA%E3%82%B9%E3%80%82CH%5B17%5D%E3%80%82CSR(%E7%A4%BE%E4%BC%9A%E8%B2%A2%E7%8C%AE%E6%B4%BB%E5%8B%95)%E3%80%82B.%E3%83%95%E3%83%A9%E3%82%B0%3D%201%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1927871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC5566%20EMIOS%20SAOC%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1927871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1925098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC5566%20EMIOS%20SAOC%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1925098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1924953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC5566%20EMIOS%20SAOC%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1924953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%81%3CBR%20%2F%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82EMIOS%E3%81%AEChanel%2016%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%83%90%E3%82%B9D%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%AA%E3%80%81EMIOS%20Channel%2017%E3%81%AESAOC%E3%81%AFEMIOS%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E5%8B%95%E4%BD%9C%E5%8F%AF%E8%83%BD%E3%80%82CH%5B16%5D%E3%80%82CADR%E3%81%A7%E3%81%99%E3%80%82R%26gt%3B%3DEMIOS%E3%81%A7%E3%81%99%E3%80%82CH%5B17%5D%E3%80%82CADR%E3%81%A7%E3%81%99%E3%80%82R%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%9F%E3%83%AA%E3%83%BC%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1924931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC5566%20EMIOS%20SAOC%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1924931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Ech17%20%E3%81%AB%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%20%E3%83%90%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81ch8%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20ch16%20(%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%20US%20D)%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PetrS_0-1722834624619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PetrS_0-1722834624619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F291845iD193C42DE29F6BB6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PetrS_0-1722834624619.png%22%20alt%3D%22PetrS_0-1722834624619.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
