AN5374 eTPU config
AN5374 eTPU config
William_Klaus
I've been trying to run a code example based on AN5374, but I did not succeed. I can't see any outputs on the pwm pins. The master channel pin is not showing any output either. In the document, it wasn't clear when to call the function "etpu_pwmm_master_irq()". My project is attached below, I used the pwmm API from the cw_etpu website.
Am I missing something?
edit: I've tried the recommendations on this other question but it's still not working.
davidtosenovjan
Have you tried to investigate eTPU registers in the debugger?
Do you have properly setup SIU module for used channels?
davidtosenovjan
William_Klaus
Indeed, the problem was I haven't configured the SIU. Thank you.
