program a new chip
program a new chip
843 次查看
Divya28
We are working on a PCB which has following chip MPC8315CVRAFDA. we need to program using a JTAG debugger (LA-7729 JTAG Debugger) with the following script files with the extension .cmm
Is it possible to convert this .cmm to .svf file format(or any other file format which is accepted by this chip?) and upload using normal JTAG developer
796 次查看
Harry_Zhang
Hi @Divya28
Yes, to convert. cmm files to. svf files, you need to use appropriate conversion tools or software. Once you successfully convert the. cmm file to an. svf file, you can use regular JTAG developers to upload it to your chip.
Hope this will help you.
Hang
