Hello tcwong@buffalo.edu
To configure the UART Baud rate you have to to modify the field SBR contained at the registers UARTx_BDH and UARTx_BDL. The baud rate is given by this formula:
The function UART_Init() in the driver already sets the desired Baud rate.
Please configure manually the baud rate by modifying the SBR field directly.
Refer to chapter 33.4.1 Baud rate generation on the KE06Z Reference manual.
Let me know if this helps.
Omar
