How to use a etimer module calculation program execution time
2,019件の閲覧回数
张松张
Fresh Out Contributor
Using SDK etimer configuration module, the realization of the application execution time
2 返答(返信)
1,847件の閲覧回数
jingpan
usually we use systick to count program execution time. It is faster and more close to cpu core. Before you execute a program, you read the timer, and after execution, read again. The execution time is the difference.
Of course you can use other timer, such as PIT, LPTMR or PTM. But almost nobody use them in that way.
Jing
1,847件の閲覧回数
张松张
Thank you for your reply, now I use SDK configured PIT module to calculate the program execution time function.In addition, I would like to ask a question about whether the STM module must produce an interrupt, whether the interrupt can be shielded.
Look forward to your reply
