I will use USB CDC based on MCUXpressoSDK with Kinetis K27.
Can I re-distribute its driver which NXP provided with usb_examples?
If I must check the license agreement for using and re-distributing it, could you tell me it?
M.Kiniwa
Solved! Go to Solution.
Hi Masahiro Kiniwa
When you download the software package and you agree on the Software Terms and Conditions, you accept the USB drivers with license: Open Source - BSD-3-Clause Clear. I recommend you to read the license agreement for more information.
Hope this information helps.
Jorge Alcala
Hi Masahiro Kiniwa
Jorge Alcala
Hi Jorge,
Thank you for your answer.
I see that the CDC driver is included the software terms of the software package.
I confirmed it for use SDK, so I will consider the availability of CDC driver under the software terms.
M.Kiniwa
