ULink2 debugger
ULink2 debugger
4,613 次查看
taz9557
Hi, I'm new to MCUXpresso IDE (V11.3.1) and I would appreciate if someone can help me to configure ULInk2 to work with LPC1768 Microcontroller?
4,589 次查看
taz9557
Hi Pavel,
Thanks for your help.
I've got it working for now on a machine which does not have Keil uVision installed.
Thanks Again.
Best Regards
Taz
4 回复数
4,590 次查看
taz9557
Hi Pavel,
Thanks Again.
Best Regards
Taz
4,602 次查看
Pavel_Hernandez
In order to understand, are you working with Arm Mbed LPC1768 Board?
Pavel
4,598 次查看
taz9557
No I'm working with Keil MCB1700 dev board.
Taz
4,595 次查看
Pavel_Hernandez
I reviewed the Ulink, that's a debugger from Keil, we do not have support for that instrument. I suggest searching the [getting start] from the vendor page.
Pavel
