Refresh automatically before build
5,385 次查看
kensu
Contributor V
For MCUXpresso, how to refresh automatically every time before build?
Because I don't want to refresh manually the project while I add a source code file.
Ken
标记 (2)
5,193 次查看
BlackNight
6 回复数
5,193 次查看
lpcxpresso_supp
How exactly are you adding new source files? If you create new files within the IDE itself, or drag'n'drop files from Windows Explorer (etc) into the project inside the IDE's Project Explorer view - then the new files should automatically be detected.
MCUXpresso IDE Support
5,193 次查看
BlackNight
I believe his problem case is that the extra file(s) are created outside the IDE, and that way the IDE is not aware it and does not included.
Erich
5,193 次查看
kensu
Contributor V
Hi Erich
Yes, sometimes, team members may add source code outside IDE (ex: SVN), so I want to know how to set.
Thanks for your support, I will wait.
Ken
5,194 次查看
BlackNight
Hi Ken,
hopefully this is what you are looking for:
Automatically Refresh Eclipse Projects before Build | MCU on Eclipse
Erich
5,193 次查看
kensu
Contributor V
Hi Erich
Thanks a lot.
This article solved my problem.
Ken
5,194 次查看
BlackNight
Hi Ken,
I solved that problem in the past and solved it with a custom builder. I would need some time tonight to write it up. I hope it can wait for a few hours.
Erich
