Debug Failed while using QN9080 example application
已解决
跳至解决方案
3,424 次查看
smittal2
I'm new to NXP. I'm working on QN9080 chip. I installed the SDK and MCUXpresso IDE following all instructions. However, when I tried to build and debug an example application, it gave me the following error:
Error in final launch sequence
Error: Unable to configure core for probe index 1.
Wire not connected
LinkServer has been terminated and will be restarted.
Please restart your debug session.
If the problem recurs, please power cycle your debug probe and restart MCUXpresso IDE.
Wire not connected
Can someone please help me what to do to resolve this. I'm stuck.
Thanks!
标记 (2)
1 解答
3,056 次查看
gerardo_rodriguez
Hello Sandeep Mittal,
Please take a look at the following threads and let me know if the solutions suggested there work for you:
Wire not connected on Q9080-DX LinkServer
qn908x Unable to configure core for probe index 1
Gerardo
在原帖中查看解决方案
2 回复数
3,057 次查看
gerardo_rodriguez
Gerardo
3,056 次查看
smittal2
Thanks Gerardo, it worked.
