USDHC missing in config tool
328 次查看
mttjcksn
I'm using the latest config tool and SDK to configure a project for the M7 core of the RT1176.
There is no USDHC driver available in the config tool.
Is this expected? It is very difficult to organise code nicely when the generated code is very self-contained but doesn't include all required peripherals.
223 次查看
mayliu1
Hi @mttjcksn ,
Thanks for your patience.
I check your issue with relevant Team.
The USDHC support is unfortunately not planned, as we have limited bandwidth for supporting the large scope of SDK.
The SD access is part of the middleware so we suggest  you can have a look on the middleware examples related to that topic.
We apologize for any inconvenience caused.
Best Regards
MayLiu
271 次查看
mayliu1
Hi @mttjcksn ,
Thank you so much for your interest in our products and for using our community.
I import an SDK demo "evkbmimxrt1170_sdcard_freertos_cm7", in this demo, There is  USDHC driver available in the config tool.
IDE version: MCUXPresso IDE 25.6
SDK version: MIMXRT1170-EVKB 25.6
I think you can refer to this demo.
Wish it helps you.
Best Regards
MayLiu
260 次查看
mttjcksn
Hi MayLiu, thanks for the reply. Your screenshot shows the pin configuration, I was referring to the peripheral driver. I don't see the peripheral listed in the peripheral view.
Many thanks
224 次查看
mayliu1
Hi @mttjcksn ,
Best Regards
MayLiu
